Speed Bleeders
  • barrelguy
    • 176
    • Oliver, BC
    Speed Bleeders
    Just installed these front and rear on my 1100SG - why in the world would anybody NOT use these?? Maybe 5 minutes to flush all lines and push new fluid through. All by my onesies - no fuss, no muss, no farting around. Just for your info.
    1980 XS 1100 Special
    Mostly stock & original
    Added Yamaha fairing (w/ 8-track!)
    Torpedo bags
    New paint (still) pending
    Stainless brake lines
    Tkat forkbrace
    Coils from Honda 1000
    Previous bikes:
    1968(?) 350 Harley Davidson
    1977 Yamaha 650
    The downside to them is that if your lines are empty, there isn't enough pressure to activate them. They work if your lines are already full though. I find that the $5 one-man bleeder kit from Harbor Freight works just as well though, and even works with empty lines.
    • BigRed
      • Mar 2010
      • 265
      • Ottawa, Ontario, Canada
      I have the speed bleeders too; they're great. I also saved my old bleeders for filling the system when it's empty. I bought a pump that will push the brake fluid in through the bleeder, so you fill the lines from the bottom, and force most of the air out the master cylinder. Once it's full, I replace the old bleeders with the speed bleeders, and push out any air that stayed in the caliper.
      • clcorbin
        • Jan 2010
        • 495
        • Albuquerque, NM
        Seeing as I can operate the level with one hand and the bleeder nut with the other, I don't see any need for speed bleeders. Plus, I use the catch tanks from Motive Pro (pressure bleeder for my four wheeled vehicles) and they keep any are from getting back into the system when you release the lever anyway.
        The last time I flushed the system, I just connected the catch tank to the bleed nipple, drained the old fluid out of the reservoir, topped it up with new fluid, cracked the bleed nipple, then pumped the handle until clean, fresh fluid was flowing out of the bleeder. No fuss. No muss. And no requirement for speed bleeders either.
        -- Clint
          Damn good idea...
          • b.walker5
            • Feb 2009
            • 1745
            • Invercargill, New Zealand
            +1 on that. I like the concept but cant see the need on a bike for that very reason. Fair enough if your 3 feet tall with the wing span of a knat, but other than that most people have long enough arms to handle the job.
            Besides I already have Speed Bleeders, they're aged 20 and 24 right now and they keep coming back for more.
              • 2117
              I got a set and dont usually have hard time bleeding brakes without them but they do make it easier.
