XJ 1100 kick start
  • 'OlGuiltyBoy
    • Oct 2011
    • 174
    • Manassas, Va.
    Originally posted by petejw
    hi OlGuiltyBoy
    if u pull the oil filler plug out u can see inside the engine
    if the internal gears are fitted or not with out
    having to remove the clutch cover.
    if you can see the gear u wont need to split the cases
    to put the rest of the stuff required for the kick start.
    if the internals arent fitted ull see a hole where the oil flows thru,
    youll have to split the cases,
    look inside both bikes and youll see the differences.
    Cool, thanks. I'll take a peek when I get home. I ended up measuring for some solid struts really quick yesterday, and looking at the clutch lever brainstorming some ideas to make a quick jockey shifter to see how I like it ...
    ~Jay
    Guilty Ones M.C.
    Manassas, Va.
    1980 Standard G
    2001 CBR 929RR
    • BigRed
      • Mar 2010
      • 265
      • Ottawa, Ontario, Canada
      Why do you need to split the cases?
      Hey, guys.
      In preparation for my 1st and 2nd gear fix, I tore into my parts engine to practice taking out the counter shaft through the oil pan and get more gears to choose from when I do the fix. Low and behold, the kick start parts inside the transmission were in there, and I could get them out through the oil pan. I just ordered the kicker shaft and associated parts off ebay for $9, and I still need to locate a kick lever. I plan to try to install them on my XJ motor when I do my fix hopefully later this week. I'll post back after to say how it goes.
        In '80 some had the internal parts and some didn't. It was the phase out year.
        • XJkid
          • Jun 2003
          • 281
          • Elk Grove, Ca.
          I ended up buying another motor, so I did not rebuild mine and thus, the kick start was relegated to just a good idea. I don't like the dependency on something like a starter clutch, so I will be very interested in how it goes. Good luck!!
