So I finally got my fancy plastic dipstick from Yamaha and was checking oil, when I dropped it in the crankcase like a moron. I tried fishing it out but it dropped down inside the sump. Am I screwed and going to have to split the case to pull it off? Any ideas? I am panicking.
Dropped plastic dipstick in crankcase
XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
Well, goodness. Look what we've got here.Tags: None -
Naw, just drop the oil pan. Depending on your exhaust system, you may not have to remove anything else.
I can drop mine by just removing the bolts. 30 minutes on and off. You don't need a gasket just some 3 bond or silicone works too.Greg
Probably just put the bike on the side stand and remove the clutch cover.Nathan
Theodore RooseveltComment
Hi Danny,
don't sweat it, there's some as has done dafter things than that.
I'm familiar with the middle drive/rear drive dipstick but what plastic Yamadipstick do they sell that measures engine oil?
The oil optic don't work for me because the sidecar gets in the way of seeing it unless I use a mirror on a stick.
Carrying one of those got to be a chore so I had to make my own dipstick from a straightened out 3" diameter stainless steel hose clamp.
The worm-drive notches mark the oil level and the T-head is bent up too wide to let the device fall down the oil filler hole.Last edited by fredintoon; 10-01-2011, 04:22 PM.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Well, don't be putting your dipstick where it doesn't belong! Those are for checking the middle and final drives!So I finally got my fancy plastic dipstick from Yamaha and was checking oil, when I dropped it in the crankcase like a moron. I tried fishing it out but it dropped down inside the sump. Am I screwed and going to have to split the case to pull it off? Any ideas? I am panicking.Skids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
It was the middle and final dipstick, yep. I never said I wasn't an idiot!
You are absolutely right :P. I stuck it in there and said "uh, I think I have this wrong", and then there it went.
I've pulled 12 bolts from the oil pan and removed the oil filter, drained the oil, but it is stuck on there good, or I'm missing bolts.XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
Well, goodness. Look what we've got here.Comment
DANG IT!! I missed the opportunity to say " Now THAT'S using your dipstick Danny!"
Nate is right, it's most likely in there stuck by the clutch pack. No, nothing much in there to worry about just be careful and pay attention and you'll be fine.Last edited by BA80; 10-01-2011, 05:23 PM.Greg
Got it!!!!!!!!!!!!!!!!!! I want to buy you all a beverage
Pulled the clutch cover, and saw it at the bottom of the hole that leads into the pan... just ALMOST out of reach. Bent a piece of wire, and managed to hook it.
Ha. I feel like such a dumbass. I also found 2 bolts I didn't pull off on the oil pan, so tomorrow I'm just going to put the rest of the bolts back in, change filter, add oil, and I should be in good shape.
Edit: Not the first time I've been accused of using my dipstick incorrectly
Last edited by Danny Crawdad; 10-01-2011, 05:37 PM.XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
Fred, this was the middle/final drive dipstick. Like I said, I'm an idiotHi Danny,
. I realized my lapse in judgment just as the dipstick slipped out of my fingers
I like your idea of hose clamp dipstick! I am going to try and make one myself. I can see my sight glass, but I don't have a center stand so it requires me to lay on the ground (bad back) and have someone push the bike towards me. Would much rather be able to sit on the bike and use a dipstick!XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
dipstik
With my bike on the sidestand, I kneel beside it, tip it up to the balance point, and with a flashlight (when I'm in the garage),look in the inspection window. Easy to do if you are careful, and DON'T jerk the bike up, and remember to ease it back down, making sure the sidestand is still out. Don't ask if I ever dropped the bike. Only did once, cause I wasn't careful.put something smooooth betwen your legs, XS eleven
79 F (Blueballs)
79 SF (Redbutt)
81 LH (organ donor)
76 CB 750 (gone to MC heaven)
rover has spokenComment
IIRC, there are 14 bolts holding the oil pan on. 2 of them are kinda recessed up a bit so you really have to look/reach for them.1980 XS850SG - Sold
-H. FordComment
