Hello all,
Been working on my 78 XS 1100 Standard and finally got it back on the road recently after 13 years in the Garage. Won't go into Detail on everything that was wrong, but the Engine and Carbs have been re-built and it is running great. Have new Tires, Re-did the shocks and brakes.. You name it.
Now.. The only issue I have is with the Turn Signals. Note: They do work. PO had put these tiny turn signals on that I do not like, I have replaced the Front Turn signals with something closer to stock that are made for the XS 1100. I just picked up the new Rear Turn Signals today and will be putting them on this weekend.
My issue is, Voltage. If the ignition is on and I hit a turn signal, it will not blink. If I have the engine idling, it will blink maybe once and then stop, If the engine is at 3k RPM or so, everything works fine (Except) If I hit the brake and the brake light come's on, the blinkers stop.
I am picturing some sort of voltage problem in the lighting circuit. I have managed to work around this by just using my front brake when turning (The Brake Switch is Missing), but I am curious if anyone else has had the issue on Voltage when the brake light come's on and what I might need to look for.
I am thinking about replacing the Signal Relay, but it seems to be working fine. I will also be doing the Blade Fuse conversion on the Fuse Box this weekend. Just not sure specifically what else I should look for.
Any comments or suggestions would be appreciated as to what I should be checking. (Will be checking all of the connectors tomorrow also).
Figured I would throw a pic in here of the bike (ALmost complete now)
~Manny~
~Manny~
