Hello everyone. I'm restoring a 78 xs11e gas tank. I really like the shape of the tank mainly cause I'm restoring the whole bike into a cafe racer. Did the acid with the bolts and por15. Turned out great.
One of the bolts that feed into the left petcock snapped. (Murphy's Law) had to be the last bolt I was re-threading to get the extra por15 out of the screw holes. Drilled and used a broken bolt remover tool. To much pressure and crushed the fitting on the left side of the tank.
I was thinking of welding the left side petcock hole shut on the gas tank. Then running T connectors for the gas and vacuum to the carbs. By doing this: I would use only the right side of the fuel tank and only one petcock.
My questions are:
Would splitting the gas and suction lines from one side of the tank cause improper mixture or suction to the carbs?
Has anyone swapped out a xs650 or xs850 fuel tank onto a 1100?
Lastly: Why are there petcocks on each side of the tank?
Any help would be appreciated. Really don't or want to spend the outargues $$$ on a tank from ebay, but if I'm thinking that there's a reason for the two petcocks on each side.....I might have to..
Sucks cause I'm almost done with the project!!!!!!!!!!!!!!!
Thanks
My questions are:
Thanks
