XJ11 carb question
    XJ11 carb question
    Can anybody tell me what the float setting is for an XJ? Is it done the same way as the 81's, using some clear tubing or is there a measured setting? What does the clear tubing method result in inches? I've got a set of carbs that I want to go through, prior to selling them, and I'd like to be able to set them up properly. What is the proper size of the main jets? Jet needle settings, if they are adjustable, pilot screw settings, etc...
    Thanks in advance
  • mitch
    • Oct 2002
    • 934
    maintance section
    all your answers are in the maintence section under carbs john .............MITCH
    Doug Mitchell
    82 XJ1100 sold
    2007 Stratoliner 1900 sold
    • Mike Hart
      • 1025
      • Seattle, Washington
      Hi John
      Yes, it's like the 81, using the tubing. BUT.... that can be a pain.
      I set mine using the other method, and there was a really long thread about my trials and tribulations of jetting my XJ.
      Page 4 of this thread has a pic of my floats, and info. For my setup, I wound up with a float height of 22mm. YMMV
      The thing is, 20mm is maximum richness, so don't go below that.
      Float measurement should be approx 20-23mm
      stock mains are 112.5
      stock pilots are 47.5
      The Search tool is an awesome thing....
