Washed bike now won't run in gear
    • 7768
    Just like it says. I washed the bike. I started it and warmed it up. It's running fine. I put it in gear and it quits. I can start it in first, but only with the throttle open, and it isn't running right. The clutch appears to be working just fine. It still seems to run perfectly in neutral. What did I do?
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    You got water inside the wire harness under the shift lever.
      • 9980
      +1....it's shorting the pickup wires to ground when you put in gear and the neutral lightgoes out.
      Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.โ€
      โ€• Albert Einstein
        • 8639
        Yep, BTDT. One time I had to ride the bike 50 miles but it was running on 2 cyl after getting wet. I disconnected the neutral switch wire under the bike and grounded it. It ran fine then. Pretty sure the water shorts out the splices in that lower left side harness. Since then, I've moved the harness forward a bit so those splices stay dry under the left side ignition cover.
        โ˜ฎ
          • 7768
          Thanx guys! That makes sense. I replaced part of that harness recently. I staggered the splices and wrapped the bundle with F4 tape and then sheathed the whole mess. I guess it's not as environmentally sound as I believed.
            • 5048
            Did you lose the neutral indicator light?
              • 8639
              IIRC, the light remained on the whole time I ran with the grounded wire.
              Marty, those wires will usually dry out overnight.
              โ˜ฎ
                • 7768
                That's what I'm going to allow. I hope I can still ride this bike in the rain! Everything else appears to be functioning perfectly.
                  • 8639
                  I have never had the bike cut out from that while riding in the rain, only after washing or trailering in the rain, YMMV. It's good to know about the neutral wire ground bypass maneuver just in case.
                  โ˜ฎ
                    • 7768
                    I'll have you show me that trick here shortly.
                      • 8639
                      No problem, hope it doesn't rain there hard enough to have to actually test it.
                      โ˜ฎ
                      • Brent
                        • 959
                        Looks like XSive rider weather will be much drier than some previous years. I had some skipping issues in the rain then. I have replaced a broken spark plug cap (sealed with RTV), sprayed 'Wire drier" on plug wires and caps, and today found the wire coming out of harness under shift lever and sprayed it. I suppose I could try to test for waterproof smoth running by spraying it thouroughly with hose (in gear too).
                        Thanks for tip, I doubt that I would ever think of this trouble shooting...
                        Brent in GA
                          • 7768
                          My bike dried, and runs great again. Just like you guys said it would.
                          • scoot
                            • Dec 2007
                            • 153
                            • Poway, CA: San Diego County
                            This site is awesome! Here's a typical obscure, unusual symptom, and bing! bang! boom! Three been- there- done- thats within an hour have it resolved. Amazing, really. This didn't happen when I was a kid.
                            scoot
                            • Brent
                              • 959
                              run in rain test
                              I checked mine to day, Warmed it up, put on centerstand, in gear.
                              It still ran while I sprayed & soaked it good with water hose.
                              Better to find problem in driveway than on road. OK - good to go. Spark caps & Plug wires good to.
                              Brent in GA
