Spark plug caps 10 or 5K ohm
  • vintagemcyclegu
    • Sep 2010
    • 32
    • Michigan
    I noticed on my 80 XS1100SG that my stock plug caps were 10k ohm and when I replaced cylinders 1 and 4 with new NGK 5K ohm caps the 1 and 4 plugs were more sootie and ran richer, didnt seem to fire as well as before. Seems like less resistance would make them run hotter not colder. Seems weird to me.
    • 5061
    Your intuition is correct. 5 ohm would not make sootier plugs.
    • XS1100 Newbie
      • Jun 2009
      • 1106
      • Battle Ground, Washington
      The heat of the plug is only how long the plug stays hot. It does not change the spark. A hotter plug would be for colder short runs only. A colder plug for long runs. The plug designed for the bike is in the middle. there are a couple racing tricks for plugs, but as to whether they really do anythin g on the bike is still up in the air i think.
      1980 XS1100LG Midnight
      1991 Honda CBR1000F Hurricane
      A cold beer and another one!
      • vintagemcyclegu
        • Sep 2010
        • 32
        • Michigan
        Plugs 1 and 4 sootie
        Plugs 1 and 4 are still sootie. Could I have a weak coil causing the problem. All 4 pilot jets are the same 1.5 turns out. cylinders 2 and 3 are a nice tan color.
          Well not all cylinders require the same number of turns out.
          Could always swap coils and see if the problem moves with the could or stays put.
          • ManagerMike
            • Mar 2010
            • 445
            • S.E. Michigan
            1 and 4 are fired by one coil and 2-3 by the other, so yeah, maybe a bad coil or related wiring, Swap coils and see if the soot issue transfers to the 2-3 plugs.
            '78 E "Stormbringer"
