carb slide internal snap ring , need sugestions
  • 1fasttrucker
    • Jun 2011
    • 77
    • Mason, Michigan
    hay guys I know someone has pulled the internal snap ring inside the carb slide to change the needle , can any body give me insite on the easy way or best way to pull these, having a bad time with simple job, no snap ring plyers I or 10 or my friends have will reach those little bugers .
    thanks
    1fastrucker
    I took a crappy snap ring pliers I had and ground the thing down till it fit in there. Miles XS also sells a pliers for this for $11.
    It is a PITA getting in there.
      • 9980
      Just a couple of small picks works well for me.
        The long-reach internal pliers are a must-have. You need them for the front MC as well (ok, not NEED, but they really help). Definitely worth the $11.
        • TADracer
          • 1417
          • Kenner, Louisiana USA
          I found that a pair of cheap hemostats I got at Harbor Freight, with the tips ground to pins works very well. Has the reach to get into the tight place and engage the holes on the clip.
          Mike Giroir
          79 XS-1100 Special
            I like that idea!
            • Aches n Pains
              • 349
              • Reston, Va.
              BEST $11 YOU WILL EVER SPEND IF YOU WANT TO WORK ON BS34 CARBS!
              Right Angled Snap ring Plier Set
              http://www.mikesxs.net/products-7.html
              Aches n Pains
              1995 KZ100P
              Pods, jets, pipes, cam adjuster, oil cooler
              1977 Ironhead - custom build
              Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
              Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                • 5048
                Wear safety glasses when you do this. I has a welt on my forehead for quit a while once from a snap ring!
                • 1fasttrucker
                  • Jun 2011
                  • 77
                  • Mason, Michigan
                  update found perfect tool
                  went to harbor freight they had a 4 pack of mini snap ring plyers the small black handled straight nose pair perfect !!
