timing fine, but vac adv keeps rpms up
  • scootjak
    • Apr 2006
    • 30
    • Staten Island, NEew York
    cleaned carbs and replaced pilot jets reset timing bike starts and idles fine but when I hit the throttle seems to hang up. Greased linkage while carbs in place and lubed throttle cable, no results. Removed carbs and cleaned grease off linkage,lubed with wd 40 and reinstalled. Same results runs fine but hangs up at about 3000 rpms. removed vac loine from carb and it idles back down. Not sure if it is the vac pod (not available at bike bandit) or something else in the timing assy. Any ideas
    79 XS 1100 sf
    First off, go back and make sure to get all the wd-40 off and relube with a cable lube. Wd-40 gets very sticky as it dries so it will make the cable hang up. Could try cleaning and tubing all.the advance parts. Also could be that you are running lean because that will cause a hanging idle.
    Have you vac synced and set the idle mix since you cleaned the carbs? If not, do that before anything else.
      Remove left side ignition cover. Vacuum advance mechanism(not vacuum can) if doesn't move freely(as in floppy free) may be staying advanced. If so, have to remove, clen and re-lubricate the bearing plate. Also check vacuum can that it is free and returns when arm is pushed in. May want to lightly lubricate shaft of vacuum can. After 30+- yrs., this is also a problem area. If this a 80 or earlier model, the centrifical advance is suspect to hanging up too.
        BTW, WD-40 is NOT a lube.......eats rust afer a fashion, and also the base metal.............likely the most misused product in the man-cave......
        • scootjak
          • Apr 2006
          • 30
          Checked and lubed vac can, advance mechanism is free moving I changed the vac line from can to carb restarted bike and again the ignition advanced and would not come down,throttle cable lubed with cable lubeand linkage seems clear snd not causing this issue
          79 XS 1100 sf
            Floats too high?
              If you are going thru the ignition under the left cover, don't forget there are mechanical advance springs behind the pick up coils that can break or get stuck either closed or open. JAT. You did say the timing was fine though.
              • mxmikie
                • Aug 2008
                • 482
                • Bouse az
                vac line hooked to manifold or carb ????
                  Nate already asked, have you sync'd the carbs? Until the carbs are properly sync'd, it simply will not run correctly.
                  • scootjak
                    • Apr 2006
                    • 30
                    Thanks for all the information. I will vacume sync the carbs and set the idle screws this evening, is this the same proceedure as mercury sync in carb maint section ? I ran the vac line from the can to the # 2 carb. The bike is a 79 special,
                    79 XS 1100 sf
