I have a 79 XS11 and am putting the filter box back on after removing the carbs. There are three bolts that hold the air filter box to the frame - one on top and one on each side. On the top there is a plate that holds the middle gear case breather tube that connects to the frame - not sure how this fits and does the breather tube just stop there? Is the left side - if sitting on bike - attachment also holding the vent tube for the fuel tank? The right side has a bracket also but it doesn't look like it holds anything. Can anyone provide help or pics? Thanks.
Routing of lines??
The my bike the right hand side bolt only has a metal corner bracket that holds nothing. I would guess it is to protest the plastic air box from being damaged by the frame when that bolt is tightened up.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 Custom -
The top one holds the wiring harness in place on the right hand side and holds the fuel tank overflow hose on the left hand side.
1978 XS500E
1981 Suzuki GS1100
1983 Honda CB900 CustomComment
Top one holds the wiring harness in place on the right side and receives the fuel tank overflow hose on the left side unless on the special. On the special I do not believe there is a purpose because there is no fuel overflow hose.
1978 XS500E
1981 Suzuki GS1100
Should have the middle drive vent in there... both models...Fast, Cheap, Reliable... Pick any two
