Parts bike
  • DCJacobs
    • Aug 2011
    • 2
    • Mahnomen, Minn.
    Parts bike
    I have an 82 XJ 1100 that runs but needs a little work. Recently I found an 81 XS 1100 on craigslist. My question is what parts are compatible between the two? The XJ need some tranny work (no 1st gear) and a left blinker assembly. So I'm really wondering if I can use those off the XS? Or since the XS is in good condition (the ad says "needs carb work, but runs"), should I just have two bikes?
    Thanks for your time,
    DC Jacobs
    Engine/driveline parts pretty much interchange (although there are important differences), some other bits, but not much else (unless the '81 is a Midnight Special, then there's a few more parts that are the same). Major differences in the electrical/ignition systems.
    As far as the bad 1st gear on the XJ (I assume it pops out of gear, as that's the typical problem), the 'fix' for that can be found in the repairs section.
    If this is the bike listed in Fargo, it's not a '81 but a '78, and even less stuff will work.
    • DCJacobs
      • Aug 2011
      • 2
      • Mahnomen, Minn.
      Thanks for the heads up on the year. I know there's some difference between the years, but I though there was too much difference to be an 81. So there's not much that'll swap over? Oh well, guess I'll look elsewhere. Thanks again!
