I need to replace my gasket but I can't Get the cover over the chain. It hits the frame of the bike and I don't think I need to drop the motor down. Ant ideas? I may have to remove the coils or the horn. Other wise ill have to save my new gasket and use the yamagoo.
valve cover removal problems
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairingTags: None -
Mine comes off tight as well. I also cannot get the front center bolt out, so i had to modify it.1980 XS1100LG Midnight
1991 Honda CBR1000F Hurricane
A cold beer and another one!Comment
It does come off with no modifications or need to remove stock coils. It's like one of those Chinese puzzles where you fiddle about and suddenly solve it. You need to lift and twist and fiddle with it...... I just removed mine without removing the Dyna coils (which are smaller than OEM anyway)XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Well ... if you check my sign..... I got aftermarkets and no resistor..." She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
led's gallore...
renthal bars
vmax tensioner
Rifle fairingComment
Once you get the resistor off there and the horns off, don't know why it won't come out without contortionism... Just did them valve check/adjust after the Colorado Rally in July, and it was not an issue at all once I got everything off that need to be taken off.
Are standards different that specials in that regard? Mine's an 80 SG.Howard
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462Comment
I have 2 XJ's and one the valve cover came off with no problems but the one I ride just will not come off, had to prop it up and use gasket in a tube.Just ME and my 82 XJ 1100. Mac 4>1-2 1/2" open baffle shotgun, no octy, K&N pod filters, LED tail/brake light & directionals, 750 FD mod, Ear Cannon air horn, modified bars and dash. "Motorcyclists are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what machine he rides as long as he belongs to the clan." Walter Davidson, Dec. 1920 edition of Harley-Davidson Enthusiast Magazine http://s851.photobucket.com/albums/ab78/justme1100/Comment
