valve cover removal problems
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    I need to replace my gasket but I can't Get the cover over the chain. It hits the frame of the bike and I don't think I need to drop the motor down. Ant ideas? I may have to remove the coils or the horn. Other wise ill have to save my new gasket and use the yamagoo.
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    gold valve emulators
    vmax tensioner
    Rifle fairing
  • CublaCron
    • Nov 2009
    • 10
    • Palominas, AZ
    probably coils
    I have dyna coils on my 81 special and I always have to remove them when I want to remove the valve cover. I'm not sure if it's necessary with stock coils though. I usually remove the horns too.
    1981 XS1100SH Special
    • DAVINCI
      • Jan 2011
      • 1048
      • Cedar Mountain, NC
      Yep. Leave the (stock) coils, pull the horn(s) and the ballast resistor. Other than that, there's nothing to get in the way of removal.
      • XS1100 Newbie
        • Jun 2009
        • 1106
        • Battle Ground, Washington
        Mine comes off tight as well. I also cannot get the front center bolt out, so i had to modify it.
        1980 XS1100LG Midnight
        1991 Honda CBR1000F Hurricane
        A cold beer and another one!
        • James England
          • 3039
          • North of England
          It does come off with no modifications or need to remove stock coils. It's like one of those Chinese puzzles where you fiddle about and suddenly solve it. You need to lift and twist and fiddle with it...... I just removed mine without removing the Dyna coils (which are smaller than OEM anyway)
          • yamahansolo
            • Aug 2007
            • 1113
            • jawga
            Well ... if you check my sign..... I got aftermarkets and no resistor...
            79 xs11 standard
            8mm msd wires
            tkat fork brace...
            Fox shocks...
            led's gallore...
            renthal bars
            vmax tensioner
            Rifle fairing
              • 3372
              Once you get the resistor off there and the horns off, don't know why it won't come out without contortionism... Just did them valve check/adjust after the Colorado Rally in July, and it was not an issue at all once I got everything off that need to be taken off.
              Are standards different that specials in that regard? Mine's an 80 SG.
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
              • justme1100
                • Jul 2008
                • 243
                • Eagle, WI
                I have 2 XJ's and one the valve cover came off with no problems but the one I ride just will not come off, had to prop it up and use gasket in a tube.
                Just ME and my 82 XJ 1100. Mac 4>1-2 1/2" open baffle shotgun, no octy, K&N pod filters, LED tail/brake light & directionals, 750 FD mod, Ear Cannon air horn, modified bars and dash. "Motorcyclists are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what machine he rides as long as he belongs to the clan." Walter Davidson, Dec. 1920 edition of Harley-Davidson Enthusiast Magazine http://s851.photobucket.com/albums/ab78/justme1100/
