idle mixture screws
  • xswilly
    • Jul 2003
    • 462
    • Hollis, maine
    idle mixture screws
    dropped off a wish list to the local dealer here in maine
    I was surprised at what I can still get from yamaha
    but the idle mixture screws are discontinued
    and i had a guy rebuild my carbs, and he stuck two of the screws
    in to tight and broke the tips off
    I guess the term lightly seated, eludes him
    anyway do any of you know where i can get them aftermarket
    http://home.securespeed.us/~xswilly/
    78E main ride, since birth the "good"
    78E Parts, the "bad" fixing up now
    78E Parts the "ugly" maybe next year
    79F Parts
    80G Parts
    75 DT 400B enduro
  • xssiveone
    • 766
    • Windsor,Ontario,Canada
    Your screws might be repairable. Clamp in a drill press, adjust untill they are turning true, and then use a file to reshape the tips. Finish off with some fine sandpaper for a smooth finish.
    Brian
    remembering the same thing!
    • jlobaido
      • Dec 2003
      • 5
      Just bought an idle mixture screw from the Yamaha dealer here in Tucson Az.
      Around $12 ea.
        I wonder if it had after-market pilot screws? I think the stock 78 screws are not tapered to form a thin point, but are instead blunt tipped and not as easily to get stuck in the pin holes as some of the later models and after market carb kits (K&L?). I would definately try the drill press, reshaping method, but round-off the tip slightly. I think the proper taper is what meters the fuel, not the tip.
          I don't think so, Skids. The '80 and '81 tips are blunt, but a blunt '78 or '79 is broken.
            Ken, now you have me racking my brain! :-)
            • xswilly
              • Jul 2003
              • 462
              • Hollis, maine
              well i compared the good one to the bad one
              and the difference is about 1/16 of an inch
              to restore the taper will shorten the screw up a lot
              which will compress the spring at the top of the screw
              and i feel will bottom the spring
              is there any kind of a cross reference guide out there
              which would tell us, if there was another model bike that would interchange
              79F Parts
              80G Parts
              75 DT 400B enduro
