berrymans and my ms
  • crazedfooter
    • 33
    • Bettendorf, IA
    berrymans and my ms
    Anybody know if berrymans will affect the finish on a ms carb? I know your not all huge fans but its how I clean em on other carbs and works great for me. Just don't want to hurt the finish on em.
    Thanks nick
    I'm reasonably sure it will eat the coating (whatever it is) right off....
    • Aches n Pains
      • 349
      • Reston, Va.
      Will it turn an unfinished carb nasty grey?
      1995 KZ100P
      Pods, jets, pipes, cam adjuster, oil cooler
      1977 Ironhead - custom build
      Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
      Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
      • crazedfooter
        • 33
        • Bettendorf, IA
        No, unfinished carbs come out looking like they did when they went in
          It will almost always ruin the seals around the butterflies and throttle shaft.
          • lee_dutcher
            • Apr 2009
            • 822
            • mason city iowa
            berry mens works great but will make them look dirty. got to clean them uo with a dremal after word or as is...
            1980 gs1000g "stock"
              • 2117
              I use Berrymens Chem tool on my bike as Sea foam is only available at select places.
              • crazedfooter
                • 33
                • Bettendorf, IA
                I know a lot of you aren't fans of berrymans on this site. I was working on my ms carbs and didn't want to hurt the finish so I didn't use it this time. Had some trouble with the float bowls on 2 carbs so I decided to fill the bowl with some berrymans to see if that would help. The pic says it all, compresed air and carb spray on two of em and the clean oneshad the berrymans in them. Imagin what could be inside your carbs. . . This little experiment has reaffirmed my belief in a carb dip, well worth the extra 5 min per carb to pull the butterfly shaft seals.
                (Hopefully this pic works, had some troble from my phone)
                My .02
                Nick
                  5 min! I want some of what you are smoking!
                  • crazedfooter
                    • 33
                    • Bettendorf, IA
                    Per carb thats about it, what r you smoking it takes so long
                    • mack
                      • 2411
                      • Ontario, Canada
                      carb cleaning
                      Well I've done seven sets of carbs now, I've made all the mistakes looking for the easy clean. All I will use now is a big ultra sonic machine, hot water and palmolive dish soap and a tooth brush, followed by canned spray carb cleaner. TLC may not be the quickest but always works best. However I completly strip the carb bodies.
                      mack
                      79 XS 1100 SF Special
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      https://youtu.be/wB5Jfbp6SUc
                      https://youtu.be/RaI3WYHSuWA
                      Frankford, Ont, Canada
                      613-398-6186
                        I have a XS650 Heritage Special. It had black carbs. The black did not stand up to carb cleaner. I don't remember what took the finish off, but I'm sure any carb cleaner would do it.
                          Try this. It works quite well and won't harm finishes or seals.
                            http://www.knmotorcycles.com/pages/c...eaner-dip.aspx
                            I'm told that stuff works good in an old crock pot.
                              Then do your freakin' dishes! I used it and it worked damn good.
                              If your lookin' for something that won't hurt the finish and the seals. That's the stuff.
