where to find?
+ More Options
Posts
  • B.B.
    • Aug 2011
    • 79
    • corsicana , Texas
    where to find?
    Any suggestoins on were to find a brass washer for the main jet in the carbs, and also were to find the rubber piece that goes in the petcock or should i just buy the whole repair kit? thanks
    Brian
    1980 xs1100 Special - Work in progress
    As to the brass washer, I would be comfortable using an aluminum or SS washer of the same size and thickness.
    As to the petcock piece, I would spring for the rebuild kit myself.
      You might be able to get both from georgefix on ebay. He is usually willing to make custom packages.
      • James England
        • 3039
        • North of England
        I've seen the washers and the petcock kits on eBay. The washers came in a set of 4 and sold for about $10 or so..........
        • B.B.
          • Aug 2011
          • 79
          • corsicana , Texas
          Thanks, I was just wondering. The petcocks were working fine but the gastank needed cleaning so I pulled the petcocks and when I did I knocked off the red vaccuum caps and they had some type of cellophane on them. Now I put the caps back on but since then the petcocks leak no matter if its in the on position, pri, res, or off. Any suggestions. Do I need to put something on the nipple before i put the vaccuum cap back on?
          Brian
            All surfaces clean,clean and no breaks in the gasket............as C.Bug stated, George fix can likley set U up with any kit combination you may need.
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              If they leak in the off position, they need to be rebuilt. Nothing should come out of the petcocks in the off position even with all the caps off of them, if any fuel does it means the internal parts are deteriorated and allowing the leaking.
              • B.B.
                • Aug 2011
                • 79
                • corsicana , Texas
                ok thanks thats what i needed
                Brian
                • XS1100 Newbie
                  • Jun 2009
                  • 1106
                  • Battle Ground, Washington
                  I just purchased two rubbers for my petcocks on ebay. Worked great.
                  1980 XS1100LG Midnight
                  1991 Honda CBR1000F Hurricane
                  A cold beer and another one!
