Any experience with the air pod setup on these? The factory intake seems very restrictive, but I don't want to screw with something that is working either.
K&N Air pods
The factory intake seems very restrictive, but I don't want to screw with something that is working either///////////////////then don't..........actually stock intake flows CORRECTLY in accordance with the motors flow characteristics and exhaust if stock.......81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
K&n
One thing that is a tiny bit easier to adjust for with stock exhaust is to replace the stock airbox filter with a K&N replacement like I did and then you only need to adjust for a small amount of increased flow.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
These engines because of their intake, combustion chamber and exhaust design can be very hard to tune to other than the stock airbox or exhaust as it messes up the flow characteristics. Apparently Yamaha engineers put a lot of work into tuning everything together, and unless your going to change EVERYTHING (carbs included) your going to likely have fits getting good performance at anything but WOT.Cy
Originally posted by cywelchjr View PostThese engines because of their intake, combustion chamber and exhaust design can be very hard to tune to other than the stock airbox or exhaust as it messes up the flow characteristics. Apparently Yamaha engineers put a lot of work into tuning everything together, and unless your going to change EVERYTHING (carbs included) your going to likely have fits getting good performance at anything but WOT.
There is allready a K&N factory replacement in it. I'll leave whats working alone...
Originally posted by ShootersHoliday View PostI agree completely. It "seems" restrictive, but I don't want to mess with something that was engineered by people alot smarter than me. I worked in the automotive aftermarket for years, and always stressed that point. The factory spends alot of time & money designing something to work a certain way.
There is allready a K&N factory replacement in it. I'll leave whats working alone...Cy
I put pods on mine mainly for looks and sound. Runs exactly the same as with the airbox as far as I can tell, ie, perfectly from idle to redline I did jet it a tad richer than stock. This is just my experience, not trying to be a contrarian.'79 XS11 Special, fork gaiters, Uni pods, 45 pilots, 140 mains, ditched the octy, solo seat, T kat fork brace
Purrs like a kitten, runs like a scalded cat
Originally posted by 11Rider View PostI put pods on mine mainly for looks and sound. Runs exactly the same as with the airbox as far as I can tell, ie, perfectly from idle to redline I did jet it a tad richer than stock. This is just my experience, not trying to be a contrarian.Cy
