80/81 carbs
  • mack
    • 2411
    • Ontario, Canada
    80/81 carbs
    Can someone with a spare set of these carbs post a picture showing the carb to carb brackets set up. My computer won't down load the parts picture and this is a different set up from my 79 carbs. Not sure if I'm missing something or not.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Mack, no pics but I can describe what's supposed to be there AFAIK...
    You should have the lower angle metal bracket the same as the '78-79 carbs, but instead of the 'tie' pieces between the diaphram covers like the early carbs, the '80-81 have another full-length bracket below the diaphram covers on the filter side. The only piece(s) that mounts to the diaphram cover(s) is the throttle cable bracket (which only attaches to one carb, not two like the early bit) and the octy if so equipped...
      I have some pics to go with the description, at least one carb body worth that show the brackets.
      Here is the pic of the upper racket Steve mentioned, this is on the inlet side of the carbs....
      And here is a couple with the lower bracket in it....
      Hope those help you out.
      • mack
        • 2411
        • Ontario, Canada
        Thanx
        Thanx, it was a year ago I stripped the bike down and had it all over my shop. I knew some carb parts were on the radial arm saw but couldn't find them. A search of shop followed by an interogation of my youngest, reveiled that the rusty metal rails had been used in a school bridge building project and spent most of the winter and all of this year in the sand pit behind our house. The bridge was an "A", my mood was an "F". Got em back though so no harm done. Short discussion about removing things from the shop (including tools) ensued.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
          Mack, I just had to laugh at your wayward parts... I wish I had a nickel for every time I had that discussion with my kids (all gone now, woo hoo!) You were very lucky to get them back!
          • Barnfresh
            • Mar 2009
            • 160
            • Abilene, TX
            Ha! Get him an erector set - remember those? They had parts just like carb rails!
            When the horse is dead, dismount.
            Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
