Losing my mind
  • TacomaJeepJeff
    • May 2009
    • 24
    Losing my mind
    OK, I just got the 1981 XS11 out of the shop where I spent more than its worth.
    Work done;
    Rebuilt carbs
    Carb boots
    Petcocks
    New fuel and vacum homes.
    New front brake.
    Got ~400 uneventful miles in 2 weeks.
    Starting today, I can ride it about 10 miles (freeway). It starts surging, then begins to loose power and in about 1 mile dies. Wont restart.
    I waited 30 minutes, it started right up and I got another 10 miles where it dies again.
    Feels like its starving out.
    Ideas? Besides a match.....
    Did you try opening the gas cap? A clogged vent in the cap can cause this...
    • XS1100 Newbie
      • Jun 2009
      • 1106
      • Battle Ground, Washington
      I would recheck everything the shop touched. I don't believe that there are very many, if any, shops that know how to work on these bikes. Shoot, most of us that do work on them still have troubles i bet.
      1980 XS1100LG Midnight
      1991 Honda CBR1000F Hurricane
      A cold beer and another one!
      • mack
        • 2411
        • Ontario, Canada
        Gas Cap
        Like Steve said. If you have a spare key, just leave it in the cap and drive until it acts up again the pop the cap, if it cures the issue, then remove the cap when back home and take it apart and clean it. You'll notice a small fabric filter. It's probably rotten and disintegrating and being pulled into the vent holes plugging them. Probably could use a new rubber gasket as well. You'll find that most problems you'll have are just little things. Anoying never the less. Good luck.
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • James England
          • 3039
          • North of England
          Def sounds like fuel starvation. The hole in my filler cap was blocked and I had a misfire (rather than total stop) after a few miles. I unclogged it and the problem disappeared.
          You've done 400 miles without fault. That means that anything the shop did re the carbs is probably all fine. You didn't get problems immediately on return from the shop, right? So, something's happened since then, rather than something they did not being right. Your symptoms sound like gas starvation and the filler cap is often the cause.
          There are several threads here re cleaning the vent hole.
          • soccer4m
            • 694
            take it back
            Take it back to the shop and let them check it out, as it could be alot of different things. As for advice,
            1.check gas level, is it full?
            2. petcock position-on reserve or prime?
            3. clogged fuel filters?
            4. gas cap vent check, run with lid open....
            5. pinched gas lines?
            Keep us informed,,,,good luck, Mike in S.Diego
            mike
            1982 xj1100 maxim
            1981 venture bagger
            1999 Kawi Nomad 1500 greenie
            1959 wife
            • neJeff
              • Jun 2011
              • 344
              • Nebraska
              Gas line is first place I would check. Is there a reason why you can't take it back to them and say WTF is up here?
              Current Daily Rides / Projects
              1979 Yamaha XS1100F (since 2015)...Project
              1980 Suzuki GS850G (since 2012)
              1979 Kawasaki KZ400B (since 2013)
              • neJeff
                • Jun 2011
                • 344
                • Nebraska
                Work done;
                Rebuilt carbs
                Carb boots
                Petcocks
                New front brake.
                If this is not out of line ( and even if it is ) I am curious if you would share exactly how much your bill came to with all of that service work done
                • XSive Okie
                  • Jun 2010
                  • 281
                  • Enid, OK
                  Maybe the ignition box getting hot and qutting until cooled off? I know Ford modules were notorious for that back in the day.
                  Richard
                  '79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
                  '02 Honda VTX1800C
                  • XSive Okie
                    • Jun 2010
                    • 281
                    • Enid, OK
                    Also this ^^^
                    Richard
                    '02 Honda VTX1800C
                      • 9980
                      Sounds like a gas cap issue or a kinked line to me.
                        For one reason or another, the bowls are not filling with fuel fast enough to keep up with your carbs needs. with the exception of the petcock and fuel line work, none of this pertains to the work done by the shop. Realistically, if it runs fine at start-up and for the first ten minutes, then the petcock and fuel lines are less suspect in my opinion.
                        The most likely issue is the gas cap vent mentioned. Basically, as gas is pulled from the tank, it needs air to fill the void. After a certain amount of time, if air can not get in, its like holding your thumb over the end of a straw full of fluid, the fluid can not go out, same for your gas.
                        I agree, with leaving the cap open and take it easy getting to the highway, run it with the cap open, and see what happens. Or just go ahead and pull the cap off, clean it up, and reinstall and see what happens. Cleaning the cap is about a 30 minute job really.
                        • slow mo
                          • 858
                          • ontario canada
                          pick -up coil wires ???just a good guess ,,ride safe slow mo !
                          moemcnally@hotmail.com
                          i AM THE KING OF NOTHING
                          • Spookysxs11
                            • 20
                            • Beautiful Bay City, Michigan
                            they possibly could have hooked up the fuel lines backwards not reralizing it. try running it in the PRI position and soo what happens. or like everyone else says take it back and say W T F
                            Spooky
                            A thing of beauty is a joy forever
                            11/1978 SX 1100 Special SF black metallic 59,000+ miles still kickin
                            850 FD Mod
                            • TacomaJeepJeff
                              • May 2009
                              • 24
                              Fixed!
                              I took it back with the aforementioned WTF?
                              They said the replaced fuel lines were too small and I took it out for a 10 mile, one way ride. http://www.xs11.com/forum/images/smilies/mad.gif
                              Repeated the step "I took it back with the aforementioned WTF" and added an angry face. I also took she who must be obeyed along as her angry face is much better than mine. She told them last chance or we would require a refund for all the work done. 3 roadside drops after big money repair is 3 too many I think.
                              Turns out, there is a vacuum cutoff in the octopus that was leaking. Its the single vacuum switch that sits between the vacuum and the vacuum side of the petcocks. After 10 minutes it would turn off the vacuum to the petcocks and riding would cease.
                              Cost for the work was $1900. I like old things and the XSs a lot, cheaper (way) than an HD. There is a shop in Tacoma that works on these for $79 /hour. I think they are slow , but the work seems OK. I'm not over pissed about the vacuum leak, I can see where that was a tad hard to troubleshoot.
