Sagging Directional Light
  • davidsymons53
    • 197
    • Peterborough, Ontario
    When you look at the pics, you can see that the directional light has pulled through the big rubber grommet. You can also see that the rubber grommet seems to be twisted a little bit so that the light would mount facing up to much.
    What is supposed to stop the light from pulling to the grommet? How can I turn the grommet around so the light lines up square?
    David
    1981 XS1100 Special
    Previous Bikes
    1999 Honda Goldwing Aspencade 1500
    1983 Honda Goldwing Aspencade 1100
    1982 Honda CB900c
    1984 Honda vt750 Shadow. My son's bike now.
    1984 Honda vt500 Shadow
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    Should be a big-ass washer there.
    • foreda
      • 949
      • Southwest Louisiana
      Big arse washer
      2nd the big arse washer!
      78 XS1100E Standard
      Coca Cola Red
      Hooker Headers
      1979 XS1100 Special
      1980 XS Standard
      2006 Roadstar Warrior
      • davidsymons53
        • 197
        OK. Is there an easy way to turn the grommet a little?
        David
        1981 XS1100 Special
        Previous Bikes
        1982 Honda CB900c
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          David
          IIRC once you have the turn signal in there and before you wrench down on things to get it tight but after it's up with the big washer against the back, you should be able to just rotate the light and the grommet should just turn with the light. Of course, YMMV.
          • davidsymons53
            • 197
            Thanks Cy , I'll try that.
            David
            1981 XS1100 Special
            Previous Bikes
            1982 Honda CB900c
            • TADracer
              • 1417
              • Kenner, Louisiana USA
              Your light is still assembled. The long hex nut on the back must come off and the chrome washer under that goes into the round slot on the outside of the grommet. Reinsert the signal and then there should be a washer installed over the stem from the tire side and then the nut. You probably cannot just rotate the grommet as there should be a tang on the frame that sits into a slot in the grommet. I would suggest you CAREFULLY pry the grommet out ans seat it in correctly with the tang in the slot.
              Mike Giroir
              79 XS-1100 Special
