I rinsed mine out with denatured alcohol and it worked very well. Unlike ice/water, the alcohol doesn't leave any residue behind when it evaporates. Although I can see were swirling the ice cubes around could help dislodge stubborn particles, so perhaps a two step cleaning would do a very nice job.
The compressed air on the alcohol at the end would have it completely dry and ready to go in a couple of seconds or less.
Unless, of course, the compressor has been blowing oil, which coated the inside of the hose, waiting to be sprayed out with the air.
Do you speak from experience here!
1978 XS1100E K&N Filter
ATK Fork Brace LED Dash lights
Ammeter, Oil Pressure, Oil Temp, and Volt Meters Green Monster Coils SS Brake Lines
I did finish off with the air, but left it off the vid, partly cause I figured everybody would think of it themselves, and because the battery went flat
can't say I've heard of anybody using bundy as a cleaner,,, bloody exie way of doing it
never ride faster than your gaurdian angel
can fly
1981 rh 5N5
MIDNIGHTSPECIAL
1188cc
4 into 1 pipes with a transac muffler,
as the motorcycling gods intended everything else stock std
