I know people have posted some things about this before but I didn't understand a word of it (probably cause I'm new), but my turn signals aren't working. I've replace all (visible) fuses and the flasher and still nothing. They light up but do not blink. Help please!
Another Repetative Question
What kind of flasher did you put in? If you put a normal automotive 3 prong flasher that won't work, you need either the OEM yamaha flasher and the correct 27 watt bulbs (which are not the same ones used in autos) or a 2 prong automotive flasher but you lose the auto cancel unless you do the auto cancel mod.
But there can be other issues, so the answer to the first question is key.Cy
Bike running or not?
If bike aint running you probably dont have enough voltage to trip the blinker...
If its running maybe not enough voltage to trip the blinker.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
Aftermarket shouldn't matter, which is why I asked what he replaced it with. Information, we need information, otherwise we'll end up going off half cocked, and then everybody will think this is a hardly site.Cy
NAAAA....... it's Big Dick that's half cocked.Greg
Do they start blinking if you rev it up past 3k RPM? Or when riding versus just sitting?
Due to corrosion of connectors or sometimes the voltage regulator, it is not uncommon for the blinkers not to blink at idle but work at higher revs.Life is what happens while your planning everything else!
The voltage regulator puts out more voltage at over 3k RPM, so often that will be enough to make the flasher start working. Now this is wwith the stock flasher, not being one of these sparky types, it might be a different story with that new one.Life is what happens while your planning everything else!
Also, the two prong flasher can be inserted 2 different ways in the 3 prong plug. One way works, the other doesn't....Nathan
Got a volt/ohm meter? Start there by checking the voltages at the flasher and the lights themselves. Check the ground wires. Why did you change the flasher to begin with? Did they just stop working?
I hate hate hate electrical problems!!!Jim...<><
'78 XS1100E
Previous bikes:
Early 70s Honda 90 Enduro
1998 Honda Shadow ACE
2006 Honda VTX 1300R
Dogs understand why people ride motorcycles
