Another Repetative Question
  • monhollenj
    • Jul 2011
    • 57
    • Eastern Kentucky
    I know people have posted some things about this before but I didn't understand a word of it (probably cause I'm new), but my turn signals aren't working. I've replace all (visible) fuses and the flasher and still nothing. They light up but do not blink. Help please!
    What kind of flasher did you put in? If you put a normal automotive 3 prong flasher that won't work, you need either the OEM yamaha flasher and the correct 27 watt bulbs (which are not the same ones used in autos) or a 2 prong automotive flasher but you lose the auto cancel unless you do the auto cancel mod.
    But there can be other issues, so the answer to the first question is key.
    • jwhughes3
      • 2798
      • Home of the Alamo
      Bike running or not?
      If bike aint running you probably dont have enough voltage to trip the blinker...
      If its running maybe not enough voltage to trip the blinker.
      John
      '81 XS1100H - "Enterprise"
        Aftermarket shouldn't matter, which is why I asked what he replaced it with. Information, we need information, otherwise we'll end up going off half cocked, and then everybody will think this is a hardly site.
          • 9980
          NAAAA....... it's Big Dick that's half cocked.
          • monhollenj
            • Jul 2011
            • 57
            • Eastern Kentucky
            LOL Ok guys I replaced it with a 12 V 6 amp 2 prong flasher. Yes the bike is running and the voltage should be fine
              Do they start blinking if you rev it up past 3k RPM? Or when riding versus just sitting?
              Due to corrosion of connectors or sometimes the voltage regulator, it is not uncommon for the blinkers not to blink at idle but work at higher revs.
              • monhollenj
                • Jul 2011
                • 57
                • Eastern Kentucky
                Not sure, I just started it up and noticed that they still wasn't blinking after changing the flasher.
                  The voltage regulator puts out more voltage at over 3k RPM, so often that will be enough to make the flasher start working. Now this is wwith the stock flasher, not being one of these sparky types, it might be a different story with that new one.
                    Also, the two prong flasher can be inserted 2 different ways in the 3 prong plug. One way works, the other doesn't....
                      • 8796
                      If your ground connections are flaky they might not flash, JAT.
                      • gui_tarzan
                        • Sep 2010
                        • 69
                        • Mid-Michigan
                        Got a volt/ohm meter? Start there by checking the voltages at the flasher and the lights themselves. Check the ground wires. Why did you change the flasher to begin with? Did they just stop working?
                        I hate hate hate electrical problems!!!
                        Jim...<><
                        '78 XS1100E
                        Previous bikes:
                        Early 70s Honda 90 Enduro
                        1998 Honda Shadow ACE
                        2006 Honda VTX 1300R
                        Dogs understand why people ride motorcycles
                        • redbone
                          • Oct 2007
                          • 244
                          • Waynesboro pa
                          if you haven't already, dismantle your turn signal switch and clean all the corrosion and/or possibly broken wire in the switch housing. that is a notorious place for turn signal problems.
                          testing 1-2-3
                          1980 1100 mns
