Greetings! I need some help. I am trying to remove the front wheel so I can put on a new tire and am having trouble with the front axle. I've removed:
1. the speedometer cable
2. caliper
3. the cotter pin, castle nut
4. and pinch bolt.
I then used a screw driver through the holes on the right/big-end of the axle to pull and tapped the threaded side with a mallet. The thing was not budging. I then tried some PB Blaster/penetrating catalyst and still nothing. Then I pounded the threaded side with a hammer, hit it hard, and it moved only slightly. I've now ruined the threads and am OK with buying a new axle but I desperately need to get this out! Any ideas?
2. caliper
4. and pinch bolt.
And...I then saw the diagram for the Standard forks, and realized that it only had one side of pinch bolts/caps!
But the subsequent wheel removal is tricky at best without pulling the calipers, or at least one.
