I bought a 79 xs 1100 special couple months ago, with a bypass on my lighting system. When I turned on the high beam i had no lights, but low beam worked, there is also a bypass on/ off switch rigged in from p/o that runs directly from the head light to a toggle back to the accessory fuse box. I tried taking apart the switch cleaning it and to no avail, so I picked up another switch for it figuring that may be the problem, also in the process i picked up a spare RLU, fuse box, HRU, and an extra switch. Now the problem I have is no lights at all, but if I place the switch in between Hi/Low beam I get Hi beam lights, I tried bypassing the RLU and get just hi beams, why is there no hi/low beam control??? The more I went through this seems like the more confused I got.
I would like to get rid of the accessory on/off toggle, which i tried and couldnt get anything to work at all, so i hooked it back up and now only have hi when i jump or short in between hi/low, any suggestions??? One more question: Was thinking of getting rid of the octo unit, so what do you do with the vaccuum lines??
)so I have been wondering what would make it run so rough, she would barely idle, I ran it up to the store put a tank of gas in and barely made it home, all gears doggin bad. How touchy are those needle valves??? Help!?!
Now for the octo: what do I do with the vacuum lines?? What about the vac advance coming out of the timing? Thats the last step for now.
. As for the vacuum lines, I like how you said SHOULD be hooked up, my vacuum advance was hooked into the octo unit, apparently from what I have read this cannot be correct. I still don't like all those fuel lines in there running through that unit anyhow, so it will be changed out. I already have the fuel line, filters, clamps, and will plug up the petcocks and see how that works. For visuals if I don't like it, like you said go with a y connector. If you use the y connect will you still have a working reserve on the petcock?? (curious) I guess all I will have left is get some plugs for the boot ports. Most appreciative for all the help.
