I bought a 79 xs 1100 special couple months ago, with a bypass on my lighting system. When I turned on the high beam i had no lights, but low beam worked, there is also a bypass on/ off switch rigged in from p/o that runs directly from the head light to a toggle back to the accessory fuse box. I tried taking apart the switch cleaning it and to no avail, so I picked up another switch for it figuring that may be the problem, also in the process i picked up a spare RLU, fuse box, HRU, and an extra switch. Now the problem I have is no lights at all, but if I place the switch in between Hi/Low beam I get Hi beam lights, I tried bypassing the RLU and get just hi beams, why is there no hi/low beam control??? The more I went through this seems like the more confused I got.
I would like to get rid of the accessory on/off toggle, which i tried and couldnt get anything to work at all, so i hooked it back up and now only have hi when i jump or short in between hi/low, any suggestions??? One more question: Was thinking of getting rid of the octo unit, so what do you do with the vaccuum lines??
