Oil Leak - Neutral Position Indicator
  • old_chopper
    • Sep 2010
    • 120
    • Oklahoma
    My bike is marking it's location when I park it. I know the best solution would be to not park it but occasionally I have to stop. It's leaking past the neutral position sensor. I have not pulled it yet and wondered if it has a o-ring to seal it off.
    US Army 1986-1991
    1979 1100 Special (on the road after 16 years!)
    1983 GS300L (wifes ride)
    1985 Super Glide
    2012 Super Glide
    • 8767
    Unless it is just loose, once they start leaking it is thru the center of the unit it probably can't be repaired. I tried to repair one once and broke it in the process. New one is about $16.
    http://www.boats.net/parts/detail/ya...540-00-00.html
    • old_chopper
      • Sep 2010
      • 120
      • Oklahoma
      OK. I don't have a neutral light so I might machine a plug for it. Thanks for the info.
      US Army 1986-1991
      1985 Super Glide
      2012 Super Glide
        • 8767
        You could also use a short metric bolt the proper thread pitch if you can find one with a small enough head to fit up in the recess, BTDT. IIRC, I used a rear fender bolt from a 79SF which had a small head and used the crush washer from the sensor.
          I have had oil drip from there before, but ended up being a leak of the shift cover. JAT.
