Oil Leak - Neutral Position Indicator
  • old_chopper
    • Sep 2010
    • 120
    • Oklahoma
    My bike is marking it's location when I park it. I know the best solution would be to not park it but occasionally I have to stop. It's leaking past the neutral position sensor. I have not pulled it yet and wondered if it has a o-ring to seal it off.
    US Army 1986-1991
    1979 1100 Special (on the road after 16 years!)
    1983 GS300L (wifes ride)
    1985 Super Glide
    2012 Super Glide
    Unless it is just loose, once they start leaking it is thru the center of the unit it probably can't be repaired. I tried to repair one once and broke it in the process. New one is about $16.
    http://www.boats.net/parts/detail/ya...540-00-00.html
    • old_chopper
      • Sep 2010
      • 120
      • Oklahoma
      OK. I don't have a neutral light so I might machine a plug for it. Thanks for the info.
      US Army 1986-1991
      1985 Super Glide
      2012 Super Glide
        You could also use a short metric bolt the proper thread pitch if you can find one with a small enough head to fit up in the recess, BTDT. IIRC, I used a rear fender bolt from a 79SF which had a small head and used the crush washer from the sensor.
          I have had oil drip from there before, but ended up being a leak of the shift cover. JAT.
