need a place to get carb to manafold clamps
  • 1fasttrucker
    • Jun 2011
    • 77
    • Mason, Michigan
    Hi folks I am haveing trouble finding the clamps that hold the carbs on the rubber manafolds any body tell me where to go the net has nothing make modle ,year, specific . and I am told it must be (MMY) specific.
    my bike is 79 xs1100 special mikuni bs34.
    • 9980
    Mikes has 'em........http://www.mikesxs.net/products-40.html#products
    • mxmikie
      • Aug 2008
      • 482
      • Bouse az
      i have some
        Make and model- specific, maybe. Not year though. They're all the same for all the XS/XJ1100's. The smaller models fit too, I believe, but don't quote me on that. There are 2 sizes to the set, so make sure you get the right ones.
        In a pinch, you could always use a regular pipe clamp.
          I think Bug was suggesting the airbox side clamps are a different size than the intake manifold side. And that is true.
          As he stated, all of the intakes on any XS1100 engine (or XJ1100) are the same and the clamps are likewise the same.
            - - - In a pinch, you could always use a regular pipe clamp.
            Hi 'Bug,
            no you can't, they are too effin' wide to fit nice.
              Hi 'Bug,
              That's why I said "in a pinch". I know, 'cause I've done it.
                • 5062
                I threw away all of my stock and replaced them with worm-gear clamps (hose-type) clamps.
                • 1fasttrucker
                  • Jun 2011
                  • 77
                  • Mason, Michigan
                  worm gear drive clamps
                  hay did that different clamps work haveing a devil of a time getting carbs to seal
                  • ManagerMike
                    • Mar 2010
                    • 445
                    • S.E. Michigan
                    I used two #7 hose clamps in series (daisy chained) per carb. They are just as narrow as the original, cheaper, and available locally. The napa part number is BK 705 1171. Just be sure to locate them carefully so that the inboard clamp head doesn't interfere with the throttle linkage.
                    Sorry about the blurry pic, cheap camera.
                    '78 E "Stormbringer"
