Fork seal replacement
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    Originally posted by New2Me
    I used bikerphils process last night and it worked perfect. In his post he says to get a hex bolt with a 19mm head which is actually a 12mm bolt. I then placed the plastic bolt wrapper over the head of the bolt and pressed into a deep well socket. 2 extensions and a ratchet completed the "tool". With my electric impact on the outer allen bolt it worked perfectly.
    Plastic bolt wrapper
    BAMN!
    '81 XS1100H "Brutus"
    • New2Me
      • Jun 2011
      • 91
      • Morris, IL.
      The bolt I bought from Menards came in a tiny plastic bag with its dimensions on it. I just took the bolt out the bag, folded the bag over the head and stuck it in the deep well socket. It was the easiest way I could think to get the bolt to stay inside the socket with out buying a specialty tool.
      Mine is all back together except the cap because I need my neighbors help. Just cant get the assembly compressed enough to screw the cap back on by myself.
      -4:2 exhaust
      -Pods
      -Who knows what the future holds..
      • Nubian
        • Apr 2011
        • 467
        • The Big East
        I guess when I tear into mine next week i'll know what you are talking about. I just can't seem to visualize it.
        BAMN!
        • New2Me
          • Jun 2011
          • 91
          • Morris, IL.
          Here is the 12mm bolt with 2 nuts wrenched on tight so they dont back off. The assemble gets pressed into the socket after placing the wrapper over the bolt head.
          -4:2 exhaust
          -Pods
          • Nubian
            • Apr 2011
            • 467
            • The Big East
            I get it the wrap is to help wedge the bolt head into the socket so you can pull it back out.
            BAMN!
              I used a length of 1/2" threaded rod with double nuts on each end. These nuts are 3/4" across the flats, and are only .005" different from the 19mm nuts. Cheaper (and easier) to find....
              • Nubian
                • Apr 2011
                • 467
                • The Big East
                what length?
                BAMN!
                • Elevener
                  • 608
                  • small town in TEXAS
                  Get a short piece of wood, I ripped a 1x4 down and cut a notch for the cap. Push down and turn. a search would probably yield more info and a pic for this. Its easy enough to do by yourself.
                  And I cut an allen wrench and used a 18 volt impact driver with socket but I had to compress the forks with ratchet straps to get it to break lose. Just another option.
                  Trapped in time. Surrounded by evil. Low on gas.
                  1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
                    • 8931
                    Glad it worked out for you New2Me. Hope you were careful to keep everything clean inside those forks. Debris in the oil can plug up damper holes.
                      what length?
                      16-18" will be plenty....
                      • Nubian
                        • Apr 2011
                        • 467
                        • The Big East
                        Thanks, can't wait to get my parts in.
                        BAMN!
                        • Nubian
                          • Apr 2011
                          • 467
                          • The Big East
                          So basically, apart from cleaning the parts and fresh oil. A complete fork rebuild only consists of 2 new springs and 2 new seals.
                          BAMN!
                          • nikonyamaha
                            • Aug 2010
                            • 27
                            • Plano, TX
                            While you're at it check the fork legs for any dings or scratches and if you find any, use an 800-1000 grit whetstone to lightly smooth them down.
                            In addition, I installed motocross gaiters to protect the forks and seals from road damage.
                            • gui_tarzan
                              • Sep 2010
                              • 69
                              • Mid-Michigan
                              I found seals on evilBay for less than ten bucks, should I be concerned about the quality? Also, is a spring change necessary? Mine are leaking fluid around both seals but when I brought the bike home the springs seemed ok.
                              Jim...<><
                              '78 XS1100E
                              Previous bikes:
                              Early 70s Honda 90 Enduro
                              1998 Honda Shadow ACE
                              2006 Honda VTX 1300R
                              Dogs understand why people ride motorcycles
                              • cywelchjr
                                XS-XJ Super Guru(Deceased)
                                • 4450
                                • Sacramento, CA
                                You need to measure the spring length against the minimum length in the field service manual to determine if they are ok. The seals can be fine and the springs be weak, and the seals can be bad and the springs can be fine, so you have to check them. Cheap seals may not last, at least a little of the situation is the condition of the inner fork tube. Is the fork tube clean and smooth, with no marring or rust pitting? If there is marring or rust pitting on any part of the fork where the seal travels, it's unlikely that ANY seal will work. If the fork tube is in good shape a cheap seal may last for a while, but if you can get OEM seals, they could last another 30 years (some have lasted that long). Another seal brand that has been known to last well is the leakproof brand, which is made a little different than traditional seals but are supposed to work pretty well.
