I recently acquired a 78 XS1100 and cleaned the carbs from it sitting for years and changed out the 10 qts of oil it had which isnt uncommon either and fired it up and smoked like a dozen 2 strokes and rode it down the driveway and back with no issues and so I kicked it up on the center stand and held it at 4000 rpms for about 3 minutes in neutral to clear out the cobb webs and it all of the sudden jumped in gear but not first or second more like 3rd or 4th and if you shift the trans locks up or goes back to whatever gear its in. I vaguely remember YEARS ago having this issue with a 82 XJ1100 after fixing 2nd gear and I just didn't have everything tight enough to get the trans aligned properly. So I am hoping something wasn't real tight and vibrated loose while setting on the stand in neutral.
Anyone else experienced something like this and knows what is likely loose, please let me know what to check.
