battery light
  • bcknblkbird
    • Mar 2009
    • 124
    • jonesville nc
    battery light
    my xj cranks fine, runs fine, it's just that the battery light comes on and i turn it off. it still displays batt, then batt goes off, a few minutes later it starts all over again. posts are clean, level is full, dont know how old the battery is was in the bike when i bought it three years ago. can i get a battery with the sensor? any help would be appreciated thanks!
    Some just bypass the sending unit....
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      Yes, you can still buy batteries with the sensor. However, if you go to an AGM (sealed batery) or look at most after-market units, they will not normally have the sensor in them. The sensor itself needs maintenance; the XJ owner's manual has a bit about cleaning the sensor as part of routine battery maintenance.
      I did the write-up when I put an AGM battery in my XJ, and it had no provision for the sensor. One note...the write up indicates a 2K ohm resistor; the exact value is not critical. Going back, I think I used a 2.2k ohm as that is a standard value.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
      • soccer4m
        • 694
        do the bypass
        Jerry and Phil are correct, bypass the sensor,,,nothing is wrong with your battery if you have the sensor unconnected as most batteries do not have it. Do the quick resistor bypass, listed, and it will be fine. BUT, if your battery is a few years old or older,,,,,it may run ok, but be ready to buy another to be safe and also do the resistor bypass, I did it on my xj over 10 years ago to get rid of the annoying red battery light,,,,,,,,,,,Mike in Sun Diego
        mike
        1982 xj1100 maxim
        1981 venture bagger
        1999 Kawi Nomad 1500 greenie
        1959 wife
