Gregs project
  • NewGuy
    • Aug 2011
    • 46
    • Tuscon, AZ
    Hi NewGuy,
    what air inlets you got that are anywhere near the handlebars?
    the shrader valves for the forks
    80 xs11 special- pods, kerker, cafe seat/tail, clubmans.
    2000 s10- 5.3 v8 swap, cam, stall, ford rear with 3.73s and posi, upgraded brakes, lowered, traction bars, larger sway bar, and a bunch of other stuff..
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      Unless the bowl has been changed they are 80 style. That said, without pulling the bowls its not possible to tell if they are the early hybrid carbs or not.
        I have found that you cannot switch bowls between 81 and other year carbs. The brass tube is in a slightly different spot and/or the hole that the tube goes into in the bowl is shapped differently and moved over slightly.
        ฮผฮฟฮปแฝผฮฝ ฮปฮฑฮฒฮญ
        • Spookysxs11
          • 20
          • Beautiful Bay City, Michigan
          Welcome new guy
          have fun out there
          Spooky
          A thing of beauty is a joy forever
          11/1978 SX 1100 Special SF black metallic 59,000+ miles still kickin
          850 FD Mod
          • Sol
            • Apr 2011
            • 81
            • Tucson, AZ
            I'll be whatching this one!
            Tearing right into it I see!
            I hope you found that tool you were looking for.
            I thought I wanted to strip mine down but waited and now though it goes counter to what I want to look at I may need to add a back rest and some saddle bags 'cus my girl likes it so much...
            But I think I'm going to get a vicarious thrill out watching you trim yours down for one up
            Happy Wrenching!
            1980 XS1100LG (MNS)
            Tucson, AZ
            It's just like the beach, but with cactus and the tide comes in only a few times a year.
            Be nice to scooters.
            How would you feel with out the ability to get away from the cars?
            • NewGuy
              • Aug 2011
              • 46
              • Tuscon, AZ
              Happy Wrenching!
              thanks, and btw dont go to spark for valve shims any more, they tried to give me the wrong ones and only had 2 of the 4 i needed. if you need some go to iron horse bmw right across the street they have the right ones and any size you need. plus they are cheaper, $3 a piece and you dont even need to give them your old one.
              just got my motorcycle endorcement today. I want to get this thing on the road.
              I havent done much in the way of looks to the bike lately, work has been hell the past 2 weeks. but i've got the rest of the day off so i'm finishing the valves and putting the cams back in. now just gotta get the carbs done and order a few things.
              to do list.
              -finish valve adjustment
              -finish carbs
              -make new airbox or get pods
              -make cafe seat/tail(including a new tail light and blinkers)
              -get standard tank
              -fuse box mod
                I'm convinced!! //////////I'm not.........looks like hex-head bowl drains..........no BOLT drains in the 81's......
                • Sol
                  • Apr 2011
                  • 81
                  • Tucson, AZ
                  Thanks for the heads up on the shims
                  Good call on the shims. I got mine online, then had to exchange for the correct ones. after that 2 weeks wasted I lost an pilot jet and went to sparks for a new one and just asked for pricing on the shims.
                  I hope all went well on the cam pulling. I know I could not wait for the tool either. Mine was off a tooth anyway but I think I will avoid pulling them from now on. careful with the cam chain tensioner they are finnicky in all sorts of ways. Mine leaks a little oil now, the plug is no longer there.
                  I made a carb sync tool with tubing and a yard stick - they work if you don't want to shell out the $ for some real carb sticks. the only problem I have had with it is the tubing gets soft from the heat and when they do it changes my vac reading, so I stop and trim the tube and check again.
                  I did not listen when folks here told me not to ditch the air box as I was sick of removing and reinstalling the thing when I had some sticking floats. I have to say it is easier not to have to re-jet a bike. that is my current project on mine. I'm up to 225's on the mains and still lean. reading plugs is bothersome. That said I might trade you mine for something off your beast if yours came without. what I did for filters was take some 1/8" expanded steel mesh and made cut outs that lodge in the stock rubber velocity stacks followed by some uni foam cut outs. I have extra foam I will share if you are interested but then you will be having to re-jet like me. I'm out of the expanded steel but home depot has the stuff for under $10. you might need to re-jet if you go with pods as well. Happy Wrenching!
                  1980 XS1100LG (MNS)
                  Tucson, AZ
                  • Sol
                    • Apr 2011
                    • 81
                    • Tucson, AZ
                    Double checked photo
                    Looks like you have an air box in the photo. I must have read something into something. Is the one it came with ugly or not functional? For me I took mine off too fast and now I'd rather be riding more and thinking less, but I still refuse to put it back on. Really it's cus I'm stubborn.
                    1980 XS1100LG (MNS)
                    Tucson, AZ
                      I am hoping you meant 125 on the mains.
                      • Sol
                        • Apr 2011
                        • 81
                        • Tucson, AZ
                        oops! slip of the finger. yes 125 on the mains!
                        Looking forward to the next installment!
                        1980 XS1100LG (MNS)
                        Tucson, AZ
                        • TomRodgers
                          • Jun 2008
                          • 492
                          • La Porte Indiana
                          Seat....
                          I could use the seat....BADLY. kind of kapootsky without one... i have the hardware.
                          BTW....isnt it SOOOO much fun tearing into a project??!!!! I love it!!
                          Welcome aboard!!! Folks here are awesome!!! Wouldnt be riding the beasts without them!!!!!
                          '81H (my first XS ) "Grey Ghost"
                          4:1 Jardine w/ headerwrap
                          Windjammer(wiring issues)
                          New paint/brakes to come!!
                          '80G FrankenBike (parts bike)
                          '80G to fix "BlackSunshine"
                          Stock Pilots/125 mains
                          Pod filters; 4:1 Kerker??
                          SS Brake lines w/ new M/C's
                          LED Brake Lite
                          Needs paint....
                          • NewGuy
                            • Aug 2011
                            • 46
                            • Tuscon, AZ
                            drove all the way to the other side of town to find the parts stores closed today. both of em...
                            got the metal for fabbing a seat pan, getting ready to order a few things from mikes if i dont findem used.
                            • NewGuy
                              • Aug 2011
                              • 46
                              • Tuscon, AZ
                              small update
                              figured i would update the little i have done since im on.
                              -got new tail light and licence plate mount/light
                              -e-bay pods(i know i gotta fix the inlets)
                              -the valves are all gapped correctly now and buttoned up, along with timing chain adjustment.
                              -hacked off the last few inches of the frame, new seat pan is half way done with fab work.
                              progress has been slow as work has been busy, but its coming along. pics when i get home tonight.
                                Large bowl drains....................80carbs...........
