I want to purchase a whole engine rebuild kit. I have searched for this topic on the forums but didnt really find anything. Does anyone know where I can get a top and bottom rebuild kit?
Engine Overhaul
Bottom end bearings are near impossible to find.
What all from the top are you looking for?
A kit though is non existent. What is your reasoning for all this?Nathan
Theodore Roosevelt -
The only type of a kit I have seen is a WISECO PISTON KIT. They are not cheep. Its a overbore piston kit.
Here is one on e-bay
1980 XS 1100SG
Dyna 3 Ohm Hi Output Coils
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCTComment
Get a set of micrometers and/or an accurate caliper and a manual and take the motor down. Measure everything and I bet you will find all is still in tolerance. These motors are fairly bulletproof and unless seriously abused should not eat up bearings, rings, pistons, etc. I would not get into the oultay of cash and time to locate engine parts until you know you must replace something.
Just my thoughts.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
As Nate said, there are no 'kits'. If you search eBay, you'll find NOS dealer 'kits' for the rod and main bearings for sale occasionally (figure about $200 each if you can find them), but these will be all the sizes that were available. 'Standard' oversize pistons are all-but-impossible to find; again, searching eBay will turn up singles, you may be able to come up with a full set from several vendors. Typical prices are about $50 each. There's a few companies that can make them for you, but cost goes to about $100 each. You may still be able to get rings from Yamaha (they were available at least up to recently), again, about $50 per cylinder. Some aftermarket sets have surfaced recently, some owners have filed the oversize sets down to fit the standard bore with decent results. As Ozz said, the only kits out there are the Wiseco ones (either the 1179 or 1196cc) but these will require an overbore. You can have $7-800 in just parts if doing a full rebuild, IF you can find them...Fast, Cheap, Reliable... Pick any two
If the compression is a bit, or even a lot low, then do a full leakdown test. It will tell you where the leakage is, which will tell you a lot about what may need to be done to bring it back into shape.Ken TalbotComment
I just recently put a Wiseco 1196 piston kit in my 1982 XJ1100. This kit is amazing, added tons of powe. No problems and bike is running great. I did the upgrade for peace of mind, still have stock pistons, spare cylinder, head if anyone needs them.
Thanks
JamieComment
You're looking at the same thing on a harness; no longer available. If yours has been hacked up up, you'll have to look for a good used one. If it hasn't been chopped on, the usual troubles on these is dirty plug connectors which can be cleaned. You also need to get the right year/model, as there are differences; your '79 SF is a one-year-only model. It is possible to to adapt other XS11 harnesses, but none will be exactly right as you get them.
Rebuilding/restoring one of these bikes can be a challenge because of the poor parts supply; other than normal 'consumables' (like brake pads, cables, brake/carb rebuild kits, etc), you're pretty much limited to the used market for replacements.Fast, Cheap, Reliable... Pick any two
