It just died
  • lancelot455
    • Sep 2010
    • 174
    • Regina,Saskatchewan,Canada
    It just died
    Was out riding today
    When i got home just as i pulled up the bike died before i was even stopped. Hit the start button and nothing. When i push the button the lights dim but the starter will not spin over at all. Battery is good. This also happened yesterday when i went to start the bike after a short ride. Tried to push start it and nothing. Then after about 10 minutes i hit the button and it fired right up.
    Any idea's on what i should be checking and how?
    82 XJ1100
    Canada
    2006 V-Star 1100 custom
  • CatatonicBug
    • 6117
    • Clinton, UT
    Perhaps the starter solenoid? Can you arc across the leads on the solenoid and get the starter to spin? Of course, that doesn't explain why it died in the driveway though... Is your battery charging properly? Check the voltages at idle and while rev'd.
      If it just simply died and you had no lights no starter no nothing, then I would suspect your ignition/key switch is going bad. May want to take it off, clean it up good, clean the connectors well. If you still had lights, but no run and no starter then perhaps you have a loose connector in the right hand emergency stop switch.
      • mjpxs11sh
        • Jan 2011
        • 299
        • N/E, Illinois
        ive looked for the emerg stop switch on my 81 Special. where is it typically located on the bike and what does it look like? its a good thing to know. thanx bro
        Max
        81 XS1100SH Black Beast Mutt
        Kerker 4/1
        stock carbs and air box.
        78 headlite, handle bars,
        1 set of ea-160/85mph guages,
        crash bars, cruise control
        Other 2 Wheelers
        78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
        94 CBR1000F jet kit,Two Bros pipe, K&N Filter
        • GARTHXS
          • Nov 2007
          • 1631
          • Seattle
          before you go and tear every thing apart ou need to load check your battery , if it reads 12v just sitting there it might still be bad , hook up a tester and hit the starter button . if the voltage caves then you have found your problem . I had the same thing happen and I tore a bunch of stuff apart until I did figure out it is the battery
          91 kwaka kz1000p
          Stock
          ( Insert clever quote here )
          • neJeff
            • Jun 2011
            • 346
            • Nebraska
            I had the same thing happen. I did not have the negative cable hooked tightly. Worth a look...
            Current Daily Rides / Projects
            1979 Yamaha XS1100F (since 2015)...Project
            1980 Suzuki GS850G (since 2012)
            1979 Kawasaki KZ400B (since 2013)
            • soccer4m
              • 694
              check the ground cable at battery to frame
              Hi,,,,maybe check the ground cable from the battery to the frame. Same thing happened to me on a ride. The ground connector to the frame just about broke and the bike acted the same, not enough to start, drove me crazy for awhile,,,,I jiggled the ground connector and it just broke completely at the frame connector. Clean up or check yours....Keep us informed..............Mike in S.Diego
              mike
              1982 xj1100 maxim
              1981 venture bagger
              1999 Kawi Nomad 1500 greenie
              1959 wife
                • 8796
                It is on the frame cross bar under the fuel tank and has two wires. Unplug it to bypass.
                Your problem sounds like it might be a melted ignition switch connector in the headlight bucket.
                  • 5062
                  Check battery water too.
                  • lancelot455
                    • Sep 2010
                    • 174
                    Battery tested good. Ground cables are attached and clean. Will check charging system and Connectors in the headlight bucket later today. It was quite hot out the day it happened 91f and with the humidex we were at about 107f
                    82 XJ1100
                    Canada
                    • lancelot455
                      • Sep 2010
                      • 174
                      Finally had time to go have a look. I checked the wiring in the headlight bucket and it all seems fine. Checked the charging system and that is all working good. 13 volts at idle and 14 volts at 2500 rpm's . i am at a loss for what it might be. Could it be in the ignition switch?
                      82 XJ1100
                      Canada
                        Yes it could be, you can take it apart and inspect it for corrosion, broken solder joints, etc.!
