how many miles/kms
  • KA1J
    • 664
    • Groton, CT
    Originally posted by Douglas Money
    Mine has a cooler. Looks like it was there from the start. Only has 34000 so far.
    I'm curious about the cooler, I do have one I installed on my Subaru for when I tow.. Don't have one on the XJ11 but I do have a really nice mini radiator that used to be part of my watercooling system on my computer. An easy access to the oil would be the oil delivery pipe running between the crankcase & head. Getting a hose with fittings should not be a problem and hooking those up to this mini radiator would be cake.
    So where do these coolers attach to the engine and if they were stock outside the states, where did the factory attach the radiator to on the bike?
    • James England
      • 3039
      • North of England
      All European bikes came with the cooler. The oil take-off point is a circular thing which sandwiches between the engine and the oil filter housing. You can buy the complete setup easily enough, especially from Germany, where there are several for sale right now. I bought one a couple of years ago, ready to bolt on, with pipes and radiator for about $30 + shipping
      • 11Rider
        • Aug 2010
        • 331
        This sounds like a no brainer especially for about 30 bucks. When you say they are available in Germany, can you give some specifics? Website? Ebay? Thank you
        '79 XS11 Special, fork gaiters, Uni pods, 45 pilots, 140 mains, ditched the octy, solo seat, T kat fork brace
        Purrs like a kitten, runs like a scalded cat
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          Mine hooks up to the lines going to the head. Probably nit the best way to do it but it seems to work ok.
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          mikes650 front fender
          led's gallore...
          renthal bars
          gold valve emulators
          vmax tensioner
          Rifle fairing
          • skipper
            • Jul 2011
            • 36
            • North Port, Fl.
            I just recently found out that factory coolers were available. Probably would have done it 25 years ago, had I known. Problem for me is I don't have room above my headers for the adapter. Being on "Social Insecurity" I haven't the disposable income to replace an exhaust system for only this reason. Then, I'd have something else to worry about (leaking hoses/cooler/etc). I really, really need something else to worry about!!!
            • mrdigitech
              • Jun 2009
              • 87
              • Minneapolis, mn
              Mine has no oil cooler. Not saying she runs perfect but I never doubt her when its time to ride.
              Far from pretty. As some will see at the "Lost in Minnesota" coming up this weekend.
              1979 XS 1100F
              Daily Rider
              DIY'r
              Minneapolis,mn
              • DAVINCI
                • Jan 2011
                • 1048
                • Cedar Mountain, NC
                149K Mi with rod & main bearings renewed at 140K. Oh, and oil cooler since 130K
                • Douglas Money
                  • Jun 2006
                  • 180
                  • Braidwood IL
                  I just had to extend the mounts on mine becuase I added the big crash hoop in the front and it took up the space where the cooler was. It was easy to adapt and everything fits just fine.
                  1979 XS1100F (runnin the wheels off it)
                  1979 XS650 (ran the wheels off it)
                  1976 CB550F (ran the wheels off it)
                  • slow mo
                    • 858
                    • ontario canada
                    how many miles/kms
                    oil cooler thread????
                    The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
                    moemcnally@hotmail.com
                    i AM THE KING OF NOTHING
                    the people here are great , doesn't matter about the bike really/hamjam ////
                    • MidniteSpec
                      • Sep 2010
                      • 12
                      • Upstate NY
                      Bought in '93 34K not well cared for,little smokie.... Valve seals, 1179 kit.
                      2011 80K Valve job+ seals...re-ring because i had it down that far anyways. May be me but seem's the i only get 50K before the seals start to go,,viton next time see how they do.
                      80LG Franken - Bags,Trunk
                      Tkat's , Mike's Blacks
                      Mac 4-2 drilled tapers, Pods
                      Wiseco 1179 @ 35K
                      750FD swap @ 80K miles 7-2-11
                      Geezer Rect.
                      Progressive's Front + Back
                      82 XJ Carbs 127.5 Mains - 55 Pilots
                      Lockhart Cooler
                      HD Barnett clutch springs @ 81K (cured slight slip)
                      • lisk
                        • Jul 2004
                        • 64
                        • Ontario, Canada
                        How many Kms/Miles
                        I've got 110,000 kms without an oil cooler or rebuild. Running like a top! But, I change the oil faithfully every 3000km. Still loving the bike!!
                        1980 XS1100 Special
                        C. Lisk
                        Cam
                          Special Ed has WELL over 120K MILES on his with no oil cooler. Still runs well, and does not use much oil.
                          • Douglas Money
                            • Jun 2006
                            • 180
                            • Braidwood IL
                            I wonder if the european models had coolers becuase of the traffic they have. In the US we might tend to have more open roads with less sitting. Unless of course you live in LA, CHI, or NYC.
                            • James England
                              • 3039
                              • North of England
                              Interesting point, that! It's the first time I've heard it but it makes sense.... You lot have all the big wide spaces, compared to lil' ole Europe
                              • skipper
                                • Jul 2011
                                • 36
                                • North Port, Fl.
                                Traffic congestion crossed my mind too. Sitting still will run head temps through the roof. Only thing is, the coolers don't have fans. So, how much help would they really be in stop and go traffic?
                                I've got 46,000 on mine. Mostly highway miles. Thing gets awfully hot on the interstate, still uncomfortable to touch crank case after sitting for three hours after 40 miles at 70 MPH.
                                Mrdigitec, what kind of oil do you use? Changed how often?
