carb synch
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Usually if 1 and 2 and open a lot more than 3 then this would happen. If so, when you go to do the final step they should start to balance out. You can get some strange readings if things are out of wack until you get them to where they belong. Mine was such the first time I did it that when I started doing 1 and 2 it died. Then I adjusted the idle and started again and things worked fine from there.
    • GARTHXS
      • 1631
      • Seattle
      Originally posted by MrOzz
      Proper sync is:
      Sync 1 and 2 so they are equal to each other. (Sync screw is between carb bodies 1 and 2)
      Sync 3 and 4 so they are equal to each other.(Sync screw is between carb bodies 3 and 4)
      Then sync 1 and 2 to 3 and 4 using the sync screw between carb bodies 2 and 3.
      When you sync 3 and 4, 1 and 2 might change. If they do, resync 1 and 2 then 3 and 4. Then you can sync 1 and 2 to 3 and 4.
      The amount of vacuum does not mater to much as long as they are equal.
      I am running pods with a dyno jet kit. The amount of vacuum on mine is 24 cmHg for all my carbs on my last sync.
      Hope this helps you.
      Ozz
      your order is off , since ther is no adjustment for #3 you use the main idle screw to adjust #3 then sync #4 to #3 then do #1 to#2 then #2 to #3 , adjust idle mix and repeat
      91 kwaka kz1000p
      Stock
      ( Insert clever quote here )
      • Ebenezer
        • May 2011
        • 67
        • Hawley, MN
        Garth,
        Your method goes against everything I have read so far, but it worked! It's running like a charm. I guess I'll go back to not even bothering to read the directions. Thanks again!
        Ryan
        1981 XS1100SH
        K&N filter
        Spade fuse block
        Barnett Springs
          • 5057
          That is the only real way to to these cabs! You might need to do some intermediate adjustments just to keep it running if 1,2,and 4 are way off from No. 3, but final adjustments are all relative to No. 3.
            • 1316
            Method Acting...
            Originally posted by Ebenezer
            Garth,
            Ebenezer,
            Garth's sync order/method is inline with what I used on my bike. It's also the order seen here as performed by a member on an XS:
              Reality is you needed to adjust your idle speed down. Wether you adjust 1 to 2 first, or 3 to 4 first should make not a hill of beans difference. However, the idle screw will change ALL of them. JMHO.
              • Ebenezer
                • May 2011
                • 67
                • Hawley, MN
                Yeah, that's what I found out. Things were so out of whack to begin with. It was only idling at 1100, but with a little adjusting #3 came right down on the carbtune. I was able to synch all four of them from there. Just put 200 miles on it, and it's running better than ever. Thanks to all!
                Ryan
                1981 XS1100SH
                K&N filter
                Spade fuse block
                Barnett Springs
