carb synch
  • Ebenezer
    • May 2011
    • 67
    • Hawley, MN
    carb synch
    Just got my carbtune in the mail and am going to attempt to do a synch. I've read a few threads on the "proper procedure" and just wondering if there is anything different on a 81 special that I need to know about. I got rid of my octy and also eliminated the prime via Steve's petcock mod. Any tips before I give this a shot?
    Ryan
    1981 XS1100SH
    K&N filter
    Spade fuse block
    Barnett Springs
    • 8893
    Make sure the engine is fully warmed up before syncing.
      __________________
      Have a good fan in front of motor while adjustments are made.
      • latexeses
        • Jun 2008
        • 1491
        • California
        You might want to run a electric fan on the engine to keep the engine from over heating while it is stationary.
        Everything on hold...
        • ccogswel
          • Jun 2005
          • 302
          • Bowling Green, Ky
          You may have to hang it upside down. I had to on mine. Nice tool to have. Small and compact.
          Chris
          79 XS1100 Standard aka: Mutt
          Gimme Fuel Gimme Fire!
          • Jeffintampa
            • Apr 2011
            • 344
            • Zephyrhills, Florida
            do you have to sync?
            Mine has been serviced on the 2500 all three oils and filter, now just about due for anouther, I have never synced but bike runs good do I have to do it?
            Bike History:1980 XS 1100 special current bike
            1980 XS 850 special wife sold
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              I don't have the manual in front of me, but even if you don't pull anything apart or actually do carb work I believe IIRC that your supposed to do a carb sync every couple of years anyways, it's one of the period tuneup items on most multi carb bikes.
              • Ebenezer
                • May 2011
                • 67
                • Hawley, MN
                Attempting to synch this thing. I got 1&2 synched. 3 is through the roof while 4 is at about the same as 1&2, relatively low on the carb tune. Do I really need to get them all as high as #3? The bike runs like crap when I get #4 at the same level as #3. It seems that either the gauge for #3 is whacked out, or something is messed up with my #3 carb. Any suggestions?
                Ryan
                1981 XS1100SH
                K&N filter
                Spade fuse block
                Barnett Springs
                • XS1100 Newbie
                  • Jun 2009
                  • 1106
                  • Battle Ground, Washington
                  Make sure you are doing it in the right order. They should all read close to the same.
                  1980 XS1100LG Midnight
                  1991 Honda CBR1000F Hurricane
                  A cold beer and another one!
                  • Ebenezer
                    • May 2011
                    • 67
                    • Hawley, MN
                    I understand that you have to synch everything to #3 in the end. However, is it normal for #3 to be maxed out on the gauge? Or is this the sign of a bigger problem?
                    Ryan
                    1981 XS1100SH
                    K&N filter
                    Spade fuse block
                    Barnett Springs
                    • MrOzz
                      • Aug 2008
                      • 782
                      • Massachusetts
                      Proper sync is:
                      Sync 1 and 2 so they are equal to each other. (Sync screw is between carb bodies 1 and 2)
                      Sync 3 and 4 so they are equal to each other.(Sync screw is between carb bodies 3 and 4)
                      Then sync 1 and 2 to 3 and 4 using the sync screw between carb bodies 2 and 3.
                      When you sync 3 and 4, 1 and 2 might change. If they do, resync 1 and 2 then 3 and 4. Then you can sync 1 and 2 to 3 and 4.
                      The amount of vacuum does not mater to much as long as they are equal.
                      I am running pods with a dyno jet kit. The amount of vacuum on mine is 24 cmHg for all my carbs on my last sync.
                      Hope this helps you.
                      Ozz
                      1980 XS 1100SG
                      Dyna 3 Ohm Hi Output Coils
                      Pod Filters
                      DynoJet Kit
                      T.C.'s Fuse Block
                      V-Max Auto CCT
                      • Ebenezer
                        • May 2011
                        • 67
                        • Hawley, MN
                        I totally understand the procedure. 1 to 2, 3 to 4, and then 1&2 to 3&4. I got that part. The problem is that 3 is maxed out on the gauge. When I synch 3 to 4 the bike barely runs because then they are both maxed out on the gauge. Then if I was to synch 1&2 to 3&4, everything is maxed out on the carbtune. I may be mistaken, but I am assuming that something else is amiss since #3 is maxed out from the beginning.
                        Ryan
                        1981 XS1100SH
                        K&N filter
                        Spade fuse block
                        Barnett Springs
                        • Ebenezer
                          • May 2011
                          • 67
                          • Hawley, MN
                          Just to clarify, the #3 carb is constantly at 42 no matter what adjustments I make. I tried changing the hoses and no matter what hose or gauge I hook it up to, #3 reads 42. So it's not the gauge or the hose. The bike does not run if I go through the proper procedure and synch them all to that number. What causes it to be that high?
                          Ryan
                          1981 XS1100SH
                          K&N filter
                          Spade fuse block
                          Barnett Springs
                          • CaptonZap
                            • Jun 2010
                            • 1748
                            • Denver
                            I don't know under what conditions you are using the carb tune, but the following link has the directions on how to set it up and how to use it.
                            It may be that the restrictor for number three is missing, or any of a number of other things.
                            Wouldn't hurt to start over with the setup, and go from there. CZ
                            <http://home.comcast.net/~jrkengr2/html/using_carbtune_ii.html>
                            • Ebenezer
                              • May 2011
                              • 67
                              • Hawley, MN
                              Been there, done that. I tried different hoses to see if it was the restrictor. Doesn't matter what hose I use or what place I put it on the carbtune. However you look at it, the third carb shoots up to 42 on the carbtune. Is there no logical reason a carb should ever read that high?
                              Ryan
                              1981 XS1100SH
                              K&N filter
                              Spade fuse block
                              Barnett Springs
