help with gas line
  • edavi394
    • 108
    • louisiana MO
    help with gas line
    Hi, I am looking for new gas line for my bike I saw some online with an anti-kink coil spring inside the line. has anyone used this? also what size line do I need xs1100 79 special. would it be better to get anti-kink coil and put on the outside? thanks
    "Lead by example, Follow by choice"
    1979 xs1100sf 10,182 miles
  • XSive Okie
    • Jun 2010
    • 281
    • Enid, OK
    Not familiar with the spring inside, but you need 1/4" I.D.
    Richard
    '79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
    '02 Honda VTX1800C
    • edavi394
      • 108
      • louisiana MO
      thanks for answering that is what I needed I think I will just get some gas line that size and put the coil over it. the other was about $5.00 per foot...
      • CatatonicBug
        • 6117
        • Clinton, UT
        No need for the coil. As long as you cut the line to the right length, there is no issue with kinking. Length is the key though.
        • OregonRider
          • Jun 2010
          • 33
          McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
          Item # 5187K63 PVC Tubing for Fuel and Lubricant 1/4" ID 3/8" OD Price is $0.61 pr foot. Order in 25, 50 & 100 foot increments. Shipping might be around $8.00 That brings the cost to $0.93 pr foot. That's still better than what you can get at the local M/C or auto store. And they always ship next day. I placed an order at 4pm PST and UPS delivered the following day. (excluding weekends)
          You can make a 1 1/2" diameter bend in it before it kinks. which is way better than what you need.
          25 feet is way more than what I need but it gives me extra for keeping several feet in my tool kit for emergencies and at that price I use two, six foot sections to keep the tank out of the way while tuning the carbs.
          Only drawback I found is the tubing is clear yellow...
          82' XJ1100 turned "bagger" with Vetter Fairing.
          • edavi394
            • 108
            • louisiana MO
            thanks for the info I still prefer to put the anti-kink coil on it. I am sure if it is just right it will not kink, but i have tried a lot of different lengths and they have all kinked. I have probably already been through 25 feet of line after putting the coils one the lines that cool my computer I am a huge believer. plus they are cheep.
            • Douglas Money
              • Jun 2006
              • 180
              • Braidwood IL
              Sounds like you are running the right petcock to the right carbs and the left to the left. That can make them kink.
              1979 XS1100F (runnin the wheels off it)
              1979 XS650 (ran the wheels off it)
              1976 CB550F (ran the wheels off it)
              • egsols
                • Jan 2006
                • 1090
                • Barrie, Ontario, Canada
                kinks? see http://www.xs11.com/forum/showthread...springs&page=2
                Ernie
                • CatatonicBug
                  • 6117
                  • Clinton, UT
                  He's got a Special, with the Octy. Not as simple as that... The Octy makes it so even an extra 1/2" in one of the 8 pieces of fuel line can cause a kink.
                    • 8054
                    Tygon fuel line
                    "TYGON fuel line the the highest quality available. Resistant to sunlight, hardening, cracking, and kinking. Flexible from --35˚ F to +165˚F."
                    Tygon is available in black or clear from 650 Central. I'm sure it's available elsewhere as well.
                    Marty (in Germany)
