I'm gonna ask a silly question here, so please don't laugh at me.
The labels are warn off on my petcocks, so I don't know which positions are which.
Normally I leave them in the vertical position (handle down) and then when it starts running dry, I go to horizontal handle toward the front of the bike.
What positions are there? On / Prime / Reserve ?
There are vacuum lines that hook to the carb ports and these should 'pull'/'suck' open the petcocks when the engine is running.
I've been reading this forum for months now and still don't have a clue about the 80G petcocks. I even took them apart 3 years ago to clean them and still don't have any ideas as to what positions there is supposed to be.
I'm asking because whenever I take the tank off, I have a problem with them leaking a little and not shutting off like I think they should.
Should I get a rebuild kit? If the internal comonents aren't bad, could I just bend the flex washer a little more to give it that little more push to shut it off with no vacuum?
Help please.
Help please.
. I think that like the orifice in the vacuum advance line, it's supposed to let the vacuum build up and stay up and not have that little valve opening and closing with each stroke of the cylinder.
