Just noticed i have no headlight (high or low beam) and no lights on my gauges. Everything else is fine and all the fuses in my t/c fusebox are fine. any particular place i should check first?
no headlight or instrument lights
open the hdlt. thats where all the connections are. each connector is different ( theres 1 the same on my 81s taped off) u can follow the guage lite wiring easily. and the hdlt is right there. let us know what u find.Max
81 XS1100SH Black Beast Mutt
Kerker 4/1
stock carbs and air box.
78 headlite, handle bars,
1 set of ea-160/85mph guages,
crash bars, cruise control
Other 2 Wheelers
78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
94 CBR1000F jet kit,Two Bros pipe, K&N Filter -
Had the same problem this week . I wasn't as lucky my head light rely was the problem. Having extra parts hanging around can be helpful
BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
Headlight relay is most likely the culprit. Relpaced mine with a standard bosch relay.'78 E "Stormbringer"
pics http://s1209.photobucket.com/albums/...tormbringer45/Comment
Check your fuse first1981 xs1100 venturer... Finally runs
Still has carb issues, but runs
For all of your Amsoil needs go to www.mrguysoil.comComment
40 amp on the switched side is a typical capacity rating for most bosch style relays, as the current draw from the low beam filament is under 6 amps (55w /12v) plus the dash illumination lamps, and only slightly higher on high beam, it is more than adequate.'78 E "Stormbringer"
Had the same problem today on a 79F, I did the RLU bypass and headlights are back. Relay had already been bypassed.2H7 (79) owned since '89
☮Comment
the connections behind the headlight all look pretty clean, i cleaned them up a bit anyway although I need a clever method for leaning the female connections. I think the RLU is right near the ballast resistor under the tank but where do I find this 'relay'?
thanks1979 XS1100SF 37000km
Green Dyna Coils
Stainless Brake Lines
1973 CB100
kevXSComment
On my 81 SH, the headlight relay is directly above the coils right up near the neck of the frame. It is a square metal box inb a rubber strap with a sleeve on top that mounts to the frame. Look right bove the coils, should be fairly easy to see when you know what your looking for and where to look.Life is what happens while your planning everything else!
78 XS750Comment
The RLU is a black plastic box held in with 2 phillips screws atop the left side of the frame by the voltage regulator. It says reserve lighting device on it or somthing similar. To bypass it, unplug and in the harness plug, jump the pins that go to blu/blk and blu/yel wires. Headlight relay bypass is jump red/yel and blu/blk wires in the harness plug.2H7 (79) owned since '89
☮Comment
bypassed RLU and Relay, still no dash or headlights
so i spliced together the blue, black and red, yellow wires on the headlight relay and also the blue/yellow, blue/black wires on the RLU and still my headlights and dash lights dont work.
when the problem starting happening, it was intermittent. some days i'd start the bike and they'd work sometimes not.
connections in the headlight enclosure looked pretty good and have also been cleaned.
can anyone help?1979 XS1100SF 37000km
Green Dyna Coils
1973 CB100
kevXSComment
At the headlight relay, you only need to splice the red/yellow and blue/black wires together. Leave the other two disconnected and insulate the ends.Fast, Cheap, Reliable... Pick any two
Green Dyna Coils
1973 CB100
kevXSComment
