no headlight or instrument lights
  • kevxs
    • Apr 2009
    • 353
    • toronto
    Just noticed i have no headlight (high or low beam) and no lights on my gauges. Everything else is fine and all the fuses in my t/c fusebox are fine. any particular place i should check first?
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
  • mjpxs11sh
    • Jan 2011
    • 299
    • N/E, Illinois
    open the hdlt. thats where all the connections are. each connector is different ( theres 1 the same on my 81s taped off) u can follow the guage lite wiring easily. and the hdlt is right there. let us know what u find.
    Max
    81 XS1100SH Black Beast Mutt
    Kerker 4/1
    stock carbs and air box.
    78 headlite, handle bars,
    1 set of ea-160/85mph guages,
    crash bars, cruise control
    Other 2 Wheelers
    78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
    94 CBR1000F jet kit,Two Bros pipe, K&N Filter
    • kevxs
      • Apr 2009
      • 353
      • toronto
      lights are working this morning, obviously a loose connection somewhere, I'll hopefully have time to dive into is this weekend
      Green Dyna Coils
      1973 CB100
      kevXS
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        Had the same problem this week . I wasn't as lucky my head light rely was the problem. Having extra parts hanging around can be helpful
        BDF Special
        • ManagerMike
          • Mar 2010
          • 445
          • S.E. Michigan
          Headlight relay is most likely the culprit. Relpaced mine with a standard bosch relay.
          '78 E "Stormbringer"
          • vanquisher51
            • Jul 2011
            • 17
            • Fort Collins, COLO.
            What size relay is the headlight relay? Thanks
            '80 Standard
            • Stepka
              • Apr 2011
              • 170
              • Shakopee, MN
              Check your fuse first
              1981 xs1100 venturer... Finally runs
              Still has carb issues, but runs
              For all of your Amsoil needs go to www.mrguysoil.com
              • ManagerMike
                • Mar 2010
                • 445
                • S.E. Michigan
                40 amp on the switched side is a typical capacity rating for most bosch style relays, as the current draw from the low beam filament is under 6 amps (55w /12v) plus the dash illumination lamps, and only slightly higher on high beam, it is more than adequate.
                  • 8766
                  Had the same problem today on a 79F, I did the RLU bypass and headlights are back. Relay had already been bypassed.
                  • kevxs
                    • Apr 2009
                    • 353
                    • toronto
                    the connections behind the headlight all look pretty clean, i cleaned them up a bit anyway although I need a clever method for leaning the female connections. I think the RLU is right near the ballast resistor under the tank but where do I find this 'relay'?
                    thanks
                    Green Dyna Coils
                    1973 CB100
                    kevXS
                      On my 81 SH, the headlight relay is directly above the coils right up near the neck of the frame. It is a square metal box inb a rubber strap with a sleeve on top that mounts to the frame. Look right bove the coils, should be fairly easy to see when you know what your looking for and where to look.
                        • 8766
                        The RLU is a black plastic box held in with 2 phillips screws atop the left side of the frame by the voltage regulator. It says reserve lighting device on it or somthing similar. To bypass it, unplug and in the harness plug, jump the pins that go to blu/blk and blu/yel wires. Headlight relay bypass is jump red/yel and blu/blk wires in the harness plug.
                        • kevxs
                          • Apr 2009
                          • 353
                          • toronto
                          bypassed RLU and Relay, still no dash or headlights
                          so i spliced together the blue, black and red, yellow wires on the headlight relay and also the blue/yellow, blue/black wires on the RLU and still my headlights and dash lights dont work.
                          when the problem starting happening, it was intermittent. some days i'd start the bike and they'd work sometimes not.
                          connections in the headlight enclosure looked pretty good and have also been cleaned.
                          can anyone help?
                          Green Dyna Coils
                          1973 CB100
                          kevXS
                            At the headlight relay, you only need to splice the red/yellow and blue/black wires together. Leave the other two disconnected and insulate the ends.
                            • kevxs
                              • Apr 2009
                              • 353
                              • toronto
                              thanks for the quick reply. i just made this change and still no lights . . .
                              Green Dyna Coils
                              1973 CB100
                              kevXS
