Can anyone tell me what correct rear brake master cylinder repair kit to buy for my bike? I am having trouble finding the correct part. 1981 1100 MS. Thanks for any information.
1981 MS rear brake cylinder repair kit
Brian
XS1100 LG "Mr T", SG "ICBM" & FJ1200
Check out the XS Part Number Finder
Be not stingy in what costs nothing as courtesy, counsel and countenance.
That kit is not available anywhere. I upgraded my rear MC to one from an XJ, since the brakes are the same setup (same lines and everything) and the MC is actually a slightly larger bore. Rebuild kits for the XJ MC are available from Chacal on XJbikes.com (see the link in my signature).1980 XS850SG - Sold
Originally posted by CatatonicBug View PostThat kit is not available anywhere. I upgraded my rear MC to one from an XJ, since the brakes are the same setup (same lines and everything) and the MC is actually a slightly larger bore. Rebuild kits for the XJ MC are available from Chacal on XJbikes.com (see the link in my signature).
. Thanks for any help or advice.[B Bone stock 1981 SX1100LH 1,430 miles bringing back to life, slowly but surely.
1973 RT3][/B]
Absolutely. That's exactly what I did. The XJ one has a wire for a fluid level sensor, and you just tie it up out of the way, since it has no where to connect on the XS. The XJ brake system is identical to the '81 MNS, except for the sensor and the bore of the MC. If you ever decide to get SS brake lines, the set for the XJ are an exact match.
As a side note, its an XS1100LH, not an SXLast edited by CatatonicBug; 07-20-2011, 11:07 AM.1980 XS850SG - Sold
Originally posted by CatatonicBug View PostAbsolutely. That's exactly what I did. The XJ one has a wire for a fluid level sensor, and you just tie it up out of the way, since it has no where to connect on the XS. The XJ brake system is identical to the '81 MNS, except for the sensor and the bore of the MC. If you ever decide to get SS brake lines, the set for the XJ are an exact match.
As a side note, its an XS1100LH, not an SX[B Bone stock 1981 SX1100LH 1,430 miles bringing back to life, slowly but surely.
1973 RT3][/B]
Nice score!Fast, Cheap, Reliable... Pick any two
