Good BS34 carb rebuild/repair tutorial
  • Aches n Pains
    • 349
    • Reston, Va.
    BS34's for Suzuki but a very nice pictorial review re: how to rebuild these carbs. Lots of good pictures of tools, techniques, etc.
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
  • neJeff
    • Jun 2011
    • 346
    • Nebraska
    Yes, thats an excellent carb tutorial. I found it a couple of weeks ago and am using it to rebuild carbs on my 80' GS550.
    Current Daily Rides / Projects
    1979 Yamaha XS1100F (since 2015)...Project
    1980 Suzuki GS850G (since 2012)
    1979 Kawasaki KZ400B (since 2013)
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      Impressive detail in that tech tip! Interesting how they remove the emulsion tube. Remove the main jet, take the washer off and replace the main jet, press the main jet and emulsion tube down and out with a screwdriver handle... no dowel needed!
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • 81xsproject
        • 3185
        • Fortuna, CA
        Hey A&P, in your signature, do you have a KZ100P or a KZ1000P? Just never heard of a 100cc police bike.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • Aches n Pains
          • 349
          • Reston, Va.
          81XSproject
          Actually, Kawasaki made 100cc police bikes for a few years as part of their "equal opportunity for very tiny cops" program.
          Fixed it.
          Thanks
          1995 KZ100P
          • 81xsproject
            • 3185
            • Fortuna, CA
            Originally posted by Aches n Pains
            81XSproject
            Fixed it.
            Thanks
            Ohhh... I thought that's why they went to Harleys.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
              Why, when I go to the link, am I looking at a blank page. Windows 7? AVG?
                Hey Marty,
                It's a PDF file, do you have Adobe Acrobat Viewer/Reader installed?
                Go to http://www.adobe.com and download and install the READER!
                Secondly, it's a 9+ MB sized file, takes a while to download even wiht cable!
                  It must be time for an Adobe upgrade.
                    Upgraded. Now it works. Imagine that!
                    It was suggested on another forum that the Yamaha carb cleaner works great in a crock pot. Source the crock pot from your local thrift store. Supposedly, that cleaner is easy on the butterfly seals.
                    • unicorncomputer
                      • Jun 2012
                      • 140
                      • Southern Vermont
                      Is this the same carb that the 79xs1100 uses? Getting ready to pull mine out tomorrow. Took off seat, gas tank and air filter today.
                      http://www.mtsac.edu/~cliff/storage/...d_Tutorial.pdf
                      79 XS1100 SF
                        The XS also uses the Mikuni BS CV carbs. There is a couple subtle differences between the stock carbs on a 79 XS11 and the ones in that tutorial. Primairly the choke linkage is not cable operated on the XS, so there is a very small metal ball and spring that locks into the detent in the choke lever. They live behind choke lever in carbs 1 and 4, (the one behind four is an extra replacement I think as there are no detents in the choke lever at that end for the ball to lock into.).
                        Also, your carbs may still have the stock brass floats. The rubber plug shown over the pilot jet is actually an aluminum screw in your carbs.
                        Personally, I would not use the main jet to push the emulsion tube out with. In alot of the carbs I have worked on, the force required to get that emulsiont ube out when they are dirty could mess up the threads on the main jet or the emulsion tube using that method. I use a wooden dowel to push the emulsion tube out, it is softer than the brass.
                          You wouldnt be able to move the emulsion tube much with the main jet in like that. Maybe 3/16" before it would hit the locator pin down in the carb body.
