Where is my diaphragm?
  • Spootinay
    • Jul 2011
    • 62
    • NE FL
    I bought a 79 xs1100 e of f (idk which yet)
    the four hoses coming off of the petcocks are going directly into the carb
    there are four smaller hoses coming off the carbs just hanging out. they are probably supposed to be hooked into the diaphragm that is non existant.
    what do i do?
  • Spootinay
    • Jul 2011
    • 62
    • NE FL
    here is a pic
    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
    • ccogswel
      • Jun 2005
      • 302
      • Bowling Green, Ky
      Welcome Spootinay!
      78 is E 79 is a F and so on.
      It appears you no longer have the octy on there any more. But someone sure has things messed up for you. But I'l try to help you a bit. It's been a while since I had been into a 79. But the long fuel lines that are coming from the back side of the petcock in place that run from the left petcock to the right carb and vis-a-versa are correct. If you understood what I just said. Now as for the front fuel line that is usually prime for that petcock is wrong. They all four should be connected to a T then into ONE to the carb. That line they have running from the front side of the petcock to the carb looks to be hooked up to the bowl vent. If you turn it to prime gas will flow out everywhere cause it's going into the bowl vent and not the float valve. But what I can't figure out is the 2 small lines coming out from under everything there. They look like bowl vents as well but I only remember one inlet for for 1-2 carbs and 3-4 and one bowl vent for 1-2 carbs and 3-4. I know someone here can better explain it then I. But hope you get some idea!!!
      Chris
      79 XS1100 Standard aka: Mutt
      Gimme Fuel Gimme Fire!
        • 9981
        GEEEZE MAN!..................I hate hearing those words, especially AFTERWARDS!!!!!!!!!!
        PO has that setup all FUBAR. Without the octy the two hoses connected to the REAR nipples should go to the lower Ts on the carbs and the FRONT nipples should be capped off.
        The upper Ts on the carbs are bowl vents and should connect to the two nipples at the top front of the airbox.
        What year and model bike have you got?
        • Spootinay
          • Jul 2011
          • 62
          • NE FL
          Ok so it is a 79 xs1100 f. Im not sure what model it is. all the decals are missing and its been repainted.
          ccogswel:
          Thanks for the welcome! You are correct there is gas spilling everywhere. I kinda have an idea of what you're saying about the lines, haha.
          BA80:
          I'll cap off the front nipples until i get an octy. And ill connect the upper t's on the carb bowl vent when i get an airbox lol.
          I need a new octy (diaphragm right?), an airbox so far. Am i missing anything else?
            • 9981
            With those valves on the tank I would have to say it's an SF. 79 Special.
            Are you running ANY kind of air cleaner?
            You can look up your V.I.N. # HERE and see exactly what year and model you have.
            • Spootinay
              • Jul 2011
              • 62
              • NE FL
              ok, sf 79 special it is if that is the original tank.
              I'll be getting a stock air cleaner on there before i ride it regularly. but for now there are four individual cleaners, but the only have wire mesh for a filter. or maybe there are filters for them.
              1979 XS1100F 2H7-020101 Magenta Red, Indigo Blue
                • 9981
                DUDE! Those screens are for drag racing and they are there to keep bugs and gravel out ONLY.
                Don't EVEN try to tune on those carbs with that **** on there.
                • Spootinay
                  • Jul 2011
                  • 62
                  • NE FL
                  Yeah i have to put in a new clutch cable, one spark plug, octy (diaphragm), and air box before i tune the carb.
                    I hate to tell you but you have a 'frankenbike'...
                    The carbs you have are late '80 or '81 (by the rear carb bracket and side-drain bowls), they may even be XJ carbs as I see a idle adjustment screw that shouldn't be there. Or they may not even be Yamaha carbs....
                    The fuel tank is definitely a Special, but you should still check motor/frame numbers to pin down what those are as there are enough differences on some stuff to make parts interchange very hard.
                    And yeah, that hose setup is terrible...
                      • 9981
                      Those are good obsevations Steve and now that you bring them to my attention, they are probably not even XS carbs.
                      The late carbs didn't have the bowl vents there above the fuel inlets,they were in an extra hole the airbox side of the carbs and those are missing also.
                        Good catch; I missed that. So those aren't XS carbs... wonder what they're off of?
                        • Spootinay
                          • Jul 2011
                          • 62
                          • NE FL
                          Should've been Bikin' Frank instead of spootinay
                          The frame vin and the motor vin are matching numbers.
                          This is now a 'name that carb' thread lol
                          They are made in Japan by the Mikuni Corp.
                          the bowls match the picture on an ebay ad for "YAMAHA XS400 XS 400 MIKUNI CARB CARBURETOR BOWL 82-83"
                          pics:
                          The million dollar questions: can i run the bike with this carb?
                            • 9981
                            I don't recognize them. The cable choke setup and fuel inlets are something different than I've seen.
                            Maybe someone in the "other bikes" forum would know. Not XS11 carbs though.
                              They could be XS carbs with the wrong bowls, I believe you can fit the later bowls on the older carbs, but I'm not sure how well they will work, as most of the elements of the carbs on the XS are common to all BS34III carbs, with the differences being in where the external attachment points are drilled and how the enricher is hooked up and the internal passages and jets.
