I find the seat height a little high on my ...sh. What options are there to make it lower ? Also my stock seat is really hard and uncomfortable . Besides replacing it what are some cheaper options ??
Options for lowering my 81 xs1100sh...???
The guy I got my SF from included some 85 virago rear shocks. They are a inch shorter. He also said he lowered the forks in the triple but the kickstand made the bike stand straight up. I haven't put the shocks on yetKeep the shiny side up
1979 XS1100SF
Mac 4-1
Drilled airbox Uni filter
Vmax bars
Virago 1" shorter shocks
30K miles
http://i1228.photobucket.com/albums/...429_135845.jpg
1981XS1100SH
'80 G Forks and Triple Tree
'80 G tank
Mac Turnouts
Virago 1" shorter rear shocks
SH Headlight
http://i1228.photobucket.com/albums/...psd6adaae1.jpg
61 Wife
83 Son
86 Son
89 Daughter -
Hi Harry,
you can remove the stock foam and replace it with a thinner pad of better material.
If you e-search "seat foam" you should be able to find the comfortable modern stuff.
The existing cover should still work with thinner foam.
I don't see you lowering the seat by more than an inch that way though.
You can also lower the bike. Let the fork tubes up through the triple trees and fit shorter rear shocks.
Be aware the exhaust will ground real easy on corners and both stands will need to be modified.Fred Hill, S'toon
"The Flying Pumpkin"Comment
I am going to do what I did to my XJ750 Midnight Maxim....cut the seat foam lower and use high density foam...it's like the memory foam for your arse. ha ha. Also one of the best covers for a seat is to use black ostrich leather..it's tough and very maintenance free. Looks great and gets a lot of complements. My wife had it done for me when I was deployed, cost right around $100 bucks for them to do everything.DirtyNasty
79 XS1100SF (POW MIA theme)
I pray for clouds, because I know there won't be any HD or fair day riders out!Comment
I have an aftermarket King & Queen seat that Yamaha offered for the specials. It was a little expensive to get it redun with new foam and leather being a large seat, but it was lowered about 1 1/2 inches. I also put XV1100 virago shocks that also dropped it about 1 inch. I'm 5"6" and I am not flat foot with both feet, but it is low enough to manouver without getting off and pushing it.
Wayne80 XS1100 SG "Phoenix"
"We are the type of band that if we moved in next door to you...Your lawn would die"
Lemmy from MotorheadComment
