gas tank gasket
  • Owestfall
    • May 2011
    • 18
    • Albany, NY
    gas tank gasket
    I'am restoring my 80 mns and need a gasket for the lid on the top of gas tank any ideas where you could get one or something similar
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    if you do a search someone posted a topic not to long ago about how you can rebuild the gas cap using an automotive thermostat gasket.
    <Edit>
    Ok, I went and did the search for you...
    1979 xs1100 Special -
    My Bike:
    [link is broken]
      Or you can get a whole gascap http://www.partsnmore.com/parts/yamaha/xs1100/?filters[fitting]=custom. It's just like the original but it has a funky lock but you can swap yours to it and keep your same key.
      15th part down on the page.
      • cywelchjr
        XS-XJ Super Guru(Deceased)
        • 4450
        • Sacramento, CA
        I think the MNS has a gold chrome cap, so replacing the cap with a white chrome cap wouldn't work very well, especially since his lock would be gold colored in that which cap? Probably best off to go with replacing the gasket, which IIRC can be had from MikesXS (or used to be) and maybe other places sell the same gasket, since it's the same one for pretty much ALL the XS line (the gasket that is).
        • BigRed
          • Mar 2010
          • 265
          • Ottawa, Ontario, Canada
          I think it's Part #20-0036
          from here: http://www.mikesxs.net/products-34.html#products
          • DeanR
            • Jan 2005
            • 1499
            • Finger Lakes NY
            The above seal that BidRed posted from Mike's works fine.
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
