this is getting old......
  • WDB_xs1100s
    • Jun 2011
    • 26
    • Ashland, Kentucky
    so im still stuck on why #2 cylinder not getting warm cleaned the carbs 3 times and still nothing its getting fuel to the plug and she has got compression. what could be my problem?
  • Shacknasty
    • Feb 2011
    • 379
    • SFV-SoCal
    I'd be looking at the coil, the wiring to the coil and the spark plug wire.
      The wiring TO the coil shouldn't make a difference. I cant remember if anyone told you this before but have you tested the resistance in that coil or the same in the plug cap?
      Also, pickup coil wire problems can be deceptive sometimes.
      • SFerinTEXAS
        • Jun 2006
        • 877
        Swap wires between 2&3, see if problem moves to 3.If so the coil,wire,cap etc. If 2 stays cold then carb or plug. Am Assuming you have compression on 2.
        79SF
        XJ11
        78E
          • 2117
          Did you remove the spark plug cap and cut the wire some?You could have some corrosion.
            With the wasted spark system these bikes employ, if the problem is in the coil, it is in both 2 and 3. So it has to be in the plug, the wire, or the cap.
            I would do as suggested and swap plug wires between 2 and 3 and see if it moves, then swap plug caps and see if it moves.
            • DELL82
              • 260
              • Houston, Texas
              Plug cap problems
              Check the plug caps. On the XJ1100 the #2 & #3 caps are long. Pull from plug and look inside, there is a screw. Unscrew the screw and a resistor will fall out with a washer and small spring, do this over some paper to catch the small parts. My #3 resistor was awash with carbon and OPEN. I replaced the resistor with 1/8" diameter brass welding rod cut to the same length. Problem cured. I later did the same thing to the other caps. Use dielectric grease inside to stop corrosion.
              My $ worth
              Dell82
              Dell82
              Houston, TX
              82' XJ1100J Maxim "LASERMAX"
              SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
              SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
              SOLD 82' CB450SC Nighthawk, parts bike SOLD
              • SFSPECBIKER79
                • Jul 2008
                • 403
                • NC
                fire
                i'd also check that plug in that clylinder. i have seen plugs that were a couple weeks old be shot. even tough they look new especially if it is a ngk they will go bad just screwed in the clylinder.switch plug around and see if problem follows the plug if not i'd look at plug wires or shoot some gas in the clylinder and put plug back in and see what happens.
                79 xs 1100 spec & 80 xs 1100 g
                • WDB_xs1100s
                  • Jun 2011
                  • 26
                  • Ashland, Kentucky
                  figured it out i think....the bike runs beautiful with the baffle in but when its out the bike is barely rideable. the bike has 140 jest so i guess ill ride it with the baffle in.
                    These bikes do need soem back pressure to run properly, it seems odd it would only effect one cylinder though.
                    • WDB_xs1100s
                      • Jun 2011
                      • 26
                      • Ashland, Kentucky
                      or should it sound like this?
                        I think that one sounds like crap with the baffle removed.
                          Here's my Kerker with no baffle,
                          A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                            If a baffle is shot or removed it can cause exhaust interference and it can affect only one cylinders efficiency to expel burned fuel.
