Is there something wrong here?-Electrical
XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model. -
Yes, or replace the auxiliary with one of these........
http://www.ebay.co.uk/itm/2-WAY-STAN...item41588d37a9
I know it's a 2 way but you could use just one of the sockets. They may even make a 1 way version.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
They do.. and they also have an 'in line' option, seen here. http://www.wiringproducts.com/contents/en-us/d347.html1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
It will. If you still need a pic, I will shoot a pic of mine today when I do the flasher relay mod, it's a G model but the wiring is close to identical, and it the same at the fuse box. But as Steve said, the hot browns go on one side feeding the none hot ones. And yes, the fuse box will handle pretty much anything you want to throw at it that the wiring harness can handle.Cy
TCs fuse box (well, the one he sells) has six slots for fuses. I have wired it up on five or six XS11s now. What I do is to put all of the fuses into the new fuse box. You end up with a 30 amp for main fuse, a 20 amp for the two larger size brown wires, and four 10 amp fuses for the ignition, headlight, tailight, and the auxillary fuses. I just run the red wire that is connected to that existing aux fuse panel up to the new fuse box and plug it into the one side. The black wire just gets grounded anywhere.Life is what happens while your planning everything else!
78 XS750Comment
Oh, if by ground you mean to connect the negative supply wire to the bike frame, well, of course if you DON'T do that, the darn thing won't work at all. ALL circuits need a return, otherwise they ain't CIRCUITS
On the other hand, GROUND has a whole different meaning in the electrical / electronic world.Former owner, but I have NO PARTS LEFT!
Good job he's in the bike world with the rest of us then!
I also would use the word 'ground' to mean connecting the negative wire to the bike frame. Of course 'ground' has a whole different meaning in the coffee world......
Last edited by James England; 07-04-2011, 01:21 PM.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Finished job.
Man I really want to get in there and clean those dust piles in the nook and crannies. But that's a job for another day. I was thinking about the main fuse but I kinda like the idea of it being under lock and key on the other side, still debating though. Aux. power for another day have not decided which route to go with that yet.
Sadly headlight issue remains the same. low beam brighter than high beam
Well going out for a cruise with the mrs. Hawks Nest (upstate NY) if anyone knows it or cares
BAMN!
'81 XS1100H "Brutus"Comment
Umm, on the high beam issue, have you checked the bulb? Does the headlight indicator come on when you switch to high beams? I'm wondering if the RLU is kicking in with a burned out high beam filament? Either that or you have a wiring problem and the headlight is backwards and it's still the same issue but it's really the low beam that is out and when you hit the high beam it's thinking it's the low and it's out so the high comes on a half brightness (which is what it's supposed to do), it's also possible that the headlight indicator might be out and that is what's happening anyways. Double check the headlight, cause it's sounding like that might be the problem.Finished job.
I would suspect the wires/connectors for the headlights. Check your left switch assembly by taking it apart and cleaning and checking EVERYTHING. I look for "loose" solder connections. If not that, check the ground wires in the headlamp bucket. You need a GOOD ground to complete the circuit.
JMTCRay Matteis
Yes, the headlamp indicator does come on when I switch to high beamUmm, on the high beam issue, have you checked the bulb? Does the headlight indicator come on when you switch to high beams? I'm wondering if the RLU is kicking in with a burned out high beam filament? Either that or you have a wiring problem and the headlight is backwards and it's still the same issue but it's really the low beam that is out and when you hit the high beam it's thinking it's the low and it's out so the high comes on a half brightness (which is what it's supposed to do), it's also possible that the headlight indicator might be out and that is what's happening anyways. Double check the headlight, cause it's sounding like that might be the problem.BAMN!
That means that the headlight high beam is burned out OR the wiring for high beam has a problem, check the bulb first, it's the most likely and easiest to check, and if the headlight indicator comes on that means the RLU has detected a burned out bulb and has switched to the OTHER half of the bulb at reduced brightness, this is by design so you don't end up with NO light when the headlight bulb burns out as it almost always goes out 1/2 at a time. Get a silverstar, costs a bit more, but a LOT more light for the same draw, it might not last as long, but I can handle replacing the bulb every 5 years or so without bothering me a bit.Cy
